Old 03-26-2010, 02:07 PM
steelronkeel steelronkeel is offline
Default Recommend MIDI keyboard/controller for PT8 + Windows 7
I bought an M-Audio Axiom 61, but I couldn't get it to work on my Windows 7 Pro machine. Can anyone recommend a similar controller that does work in Windows 7 running PT8? Akai MPK?
I got a fever and the only presciption is more cowbell!
Old 03-26-2010, 04:40 PM
BOZiN BOZiN is offline
Default Re: Recommend MIDI keyboard/controller for PT8 + Windows 7
I had the same issue. The problem is that the Axiom doesn't know where to look for the driver when in fact it is there.
Go to device manager.
Right-click the yellow ! which shows your USB Axiom as having driver issues.
Select Update Driver.
Make sure you search for the driver in the C:\Windows\ directory.
The driver should now install correctly.
In the MIDI Controllers tab, you should now be able to select your AXIOM USB keyboard.
Hope that helped.
BOZiN
BOZiN Productions
http://www.bozinproductions.com
Intel Core 2 Quad Q8300 @ 2.5 GHZ
8.00 GB DDR2
Windows 7 Professional X64
PRO TOOLS 9.0.2
M-BOX 2 Factory
MUSIC PRODUCTION TOOLKIT 2
PRO TOOLS INSTRUMENT EXPANSION PACK
M-AUDIO AXIOM 49 MIDI Controller
BEHRINGER BCF-2000 Control Surface
M-AUDIO BX8a Deluxe Monitors
BEHRINGER RX-1602 Rack Mixer
Recommend cheap and simple midi controller? Silence MIDI 2 03-27-2011 08:05 AM
Recommend MIDI keyboard/controller for PT8 + Windows 7 steelronkeel MIDI 0 03-26-2010 02:44 PM
MIDI Keyboard Controller / PT milet22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-04-2006 03:20 PM
Using a midi keyboard controller grantarctica 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-15-2005 03:06 PM
Pls. recommend great MIDI controller w/piano feel Namaste Pro Tools TDM Systems (Mac) 7 10-02-2003 03:01 PM
