Old 11-29-2005, 03:27 PM
crizdee's Avatar
crizdee crizdee is offline
Default Copy all from location to location question!
I'm trying to copy ALL regions and data from one location to another and i can't get it to copy everything!! i have set the track view to blocks(on audio tracks) and volume (on aux tracks) and this didn't work, then tried regions view on audio tracks and still it wouldn't copy everything!! i had to copy each bit one at a time!? volume/plugin automation etc etc.
Is there a quick way to copy everything in one move? i thought i had done this before with no probs before version 7! or maybe i didn't!!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-29-2005, 03:50 PM
myke2242's Avatar
myke2242 myke2242 is offline
Default Re: Copy all from location to location question!
why not selecting all and Option+drag? is that not working as well?
_____________________
HerronSFX.com
Herronsound.com/blog/
HerronSFX Instagram
Old 11-29-2005, 04:05 PM
Shawn Simpson Shawn Simpson is offline
Are you using the 'all' group? I've had problems before where I've selected a bunch of tracks/events and copied them, then put the cursor where I wanted them and pasted. There were problems if I didn't make sure the edit selection cursor wasn't extending across all of the tracks where I'd copied from. Does that make ANY sense at all??
Old 11-29-2005, 04:27 PM
Andre Knecht Andre Knecht is offline
Just a thought…
Is “Automation Follows Edits” checked?
Up to 6.9 is was found in the “Operations” menu (don’t know where it resides under 7.0, which I have yet to install).
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Question about location marker miketmbt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-24-2011 05:47 PM
Memory Location Question tomhartman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-02-2009 05:50 PM
Memory Location Question midnightsun ICON & C|24 11 01-23-2009 06:24 AM
Memory Location question justme77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-13-2008 10:08 AM
Location Window Question Bryan Pro Tools TDM Systems (Mac) 3 02-17-2000 05:21 AM
