Can a AUDIO clip be looped-end extended ???
imagine cuting & pasting a clip 4 times....but the end is a bit short and leaves a gap......is there a way to add sound like when you truncate a sample and loop the end to fade out.
even reverb or delay would work......but not in a GAP if this was video...i would freeze frame the clip then fade out and layer the next paste right over its tail. this is a good challenge i can't imagine an app thats boasts Cut & Paste would not have a way to extend--streeeech out a clip. backround:i have a guitar clip that i want to dup 4 times but only have 1 clip that needed to be edited short. thanx |
Re: Can a AUDIO clip be looped-end extended ???
Is the guitar sound sustained? Or is it rythmical in nature? Do you need to have tempo integrity maintained? If it is a sustained note, what you can do is to take a portion of the tail of the note, cut the clip near the end and a little before that. Try and do this at zero crossing points. Then take the cut section and time stretch it. You will need to experiment to get it right. Then rejoin and crossfade if you need to, but if you cut in the right place, you shouldn't need to. Don't know if this answers your question. |
I do this quite often. I basically grab a small bit of the tail and apply Pitch n' Time to lenghten it. I check carefully to make sure the new audio doesn't sound out of place compared to the preceeding file. I'll usually add a touch of reverb to the new tail to make it linger just long enough.
Takes some practice but it works like a charm!
Paul Peterson Sound Director The Old Globe San Diego, CA |
Does HD's extended disk cache also work for MIDI/instrument tracks, or just audio? | JamesAvery | Pro Tools 10 | 2 | 10-28-2011 03:28 AM |
AUDIO RECORD VOLUME OS EXTENDED giving me hell!!!! | shaunicate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-02-2006 12:00 PM |
Grid and looped audio regions no longer match | in10shun | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-01-2004 06:31 PM |
Format Extended or Extended Journaled for PT6.2.3? | AAR | Pro Tools TDM Systems (Mac) | 3 | 02-06-2004 07:46 AM |
Can external audio signals be digitally looped in and out of Pro Tools | RDJ | General Discussion | 2 | 04-11-2001 06:52 PM |
