Control 24 no longer works on update to 7.3
Hi stayed up late updating PT from 6.9.1 to 7.3 last night. Updated the Mac dual 2ghz G5 to 10.4.6 and updated PT to 7.3. It sees the 192 I/O but not the control 24. I tried to enable it under the Peripherals menu but to no avail. Is there an update for the firmware or something i missed?
thanks i advance.
Dual 2 ghz G5 Pro Tools HD2 7.3 Control 24 Glyph GT103 FW drive Internal SATA 192 I/O |
Re: Control 24 no longer works on update to 7.3
The installation cleared your ethernet controller settings. Just go in and reset/choose your Control 24 and you'll be back up.
kopper |
you may have to power cycle the c24. make sure your speakers are off when you do
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
ethernet controller settings for the Mac or in Pro tools?
thanks for the reply!
power cycle the c24? whats that? I tried turning it off and back on again, replugging the cable..
In Pro Tools.
Setup->Peripherals Click the Ethernet Controllers tab Select en0 (or en1 if you are pugged into the second ethernet port) It should find the Control 24 Ceri |
right. i did that several times and it did not find it.
Software issues might also cause that. And just installing 7.3 on top of 6.9.2 is a bad idea, if that is what you did.
Pro Tools 6.x is not compatible with any 7.x version, neither are the plug-ins. Since that was a major Pro Tools rewrite. You should try putting the 6.9 disk in or downloading the 6.9.2 update from the website and doing a clean uninstall from the "custom install" menu during the install process. Clean all of 6.9.2 off there, then run the 7.3 uninstaller from the Pro Tools Utilities Folder inside your Pro Tools Applicaiton Folder. Clean uninstall 7.3. Don't just drag folders to the trash, it's important you use the uninstaller apps. With a fresh start now you're ready to install 7.3 and there shouldn't be any issues. Good Luck |
ahh..ok...worth a shot..do i have to reinstall all of the plug ins again?
ProControl- Control Room Section NO longer works after Upgrades | adrielw | Pro Tools TDM Systems (Mac) | 8 | 06-28-2009 11:29 PM |
PT LE 7.4 no longer works on 3 different PCs | AlyssaG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-19-2008 11:27 AM |
click no longer works? | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-15-2005 09:18 AM |
OT: FireWire no longer works...... | ronev | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-30-2003 10:56 AM |
Waves 3.0 no longer works with HUI | Huby SEA | Pro Tools TDM Systems (Mac) | 2 | 11-18-2000 07:45 AM |
