Will Digi 003 work?
I own Digi 003 console and i want to build stable system Pro Tools HD or HD2 - 3. Now I have PT Native - but it not so stable under PC Win 8. Will my controller work with PT 10 or 11 with HD cards installed? I used to work with my Digi 003 - do i need change my audio interfeace? |
My 003 console works flawlessly with 10 and 11 HD on Windows 7 Ultimate. Make sure you get the right driver!!! It's all too easy to accidentally grab the RACK driver, which is not the same. Found that out the hard way.
http://akmedia.digidesign.com/suppor...81451.zip?ns=1 |
![]() Quote:
What exactly are you asking? If you can use the 003 as a control surface with a HD/TDM system? The answer to that is most definitely no. Do you want to use the 003 as an interface and use the TDM/DSP processing? The answer there is also most definitely no. you have to use a TDM/Digilink connected interface like an Omni, HD IO or 192. You cannot use the 003 with the HD/TDM and Pro Tools HD will not work at all without an interface connected to a core card. Pro Tools HD/TDM cards will not work with Pro Tools HD 11. Pro Tools HD 10 was the last version to support those cards and TDM/DSP plugins. You hopefully also realize that you will likely need to obtain TDM versions of many of your current plugins to get maximum benefit of a HD/TDM system. You should also look at voice count needs as you are sizing the system. You will also need to obtain a Pro Tools HD license as Pro Tools (standard) will not work with HD hardware. An old TDM system may be an excellent choice folks wanting a doled tracking system. But you really need to know what you are getting into with the complexity, compatibility and costs. Last edited by Darryl Ramm; 09-05-2015 at 02:06 PM. |
Digi 002 Mixer Console | Dolow Dee | Getting Started | 1 | 11-23-2014 02:12 AM |
Digi 003 console | GloryIsSilent | Buy & Sell | 1 | 09-02-2013 08:55 AM |
Digi 003 console, comand 8 or digi 003 rack plus | boabyd23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 04-28-2011 04:13 PM |
Digi 003 console+? | johnnyz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-26-2009 12:54 PM |
digi 002 console | jimmye13 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-10-2007 08:04 AM |
