Old 12-16-2009, 04:27 PM
Jonasfp Jonasfp is offline
Default Can you tag the notes in midi editor?
Im using the midi editor allot with ez drummer, and im sick and tired of the editor in LE8 compared to Reaper. Does anyone know if you can somehow tag the notes "left sidekeyboard" in the editor so you would easily know what it would hold for a drum element?
Old 12-16-2009, 04:33 PM
flommer flommer is offline
Default Re: Can you tag the notes in midi editor?
What you can do is have a single midi track for each hit, and name the tracks the way you want. Then you can set the track to only display a single MIDI note..
This has some editing advantages, but is also not quite as convenient as a dedicated MIDI drum editor GUI..
If you go to the trouble to set this up, make sure you make a template out of it so you can re-use it...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 12-16-2009, 04:52 PM
I'm doing complex fills with alot of different hit with velocities changing and so on... I'm writing music for my band this way, we play doom metal.
I could see that this with splitting everything up for someone who writes electronic or monotonous beats but not me. Anyway what is this GUI all about?
Thanks for answering in the first place :)
Old 12-16-2009, 04:59 PM
seriously, it can't be true that after spending 250€ on a program, the stock midi editing is centuries behind a 40bucks program like reaper.
Old 12-16-2009, 05:00 PM
Enable 'Colour Code MIDI Notes by Track' when superimposed.
filosofem
Old 12-16-2009, 05:02 PM
Seriously, Pro Tools ain't Reaper and you need to read the Pro Tools Reference Guide.
filosofem
Ah so each key gets it's individual color?
Old 12-16-2009, 05:04 PM
filosofem
you are right :) any other ways to customize you drum midi editing? Is there anything in the way of a plugin? GUI might help allot tho.
Old 12-16-2009, 05:28 PM
Each Key? You mean note pitch, no. Colour Code MIDI Note by Track means colour coding MIDI Note by Track. Flommer has pointed out, keep one drum instrument per track, then switch the track view to 'Single Note View' for Edit Window management. Thus Kick, Snare, etc., not only has it's own track but also has corresponding colour coding.
filosofem
MIDI Editor no sound when selecting notes grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-19-2023 03:26 PM
Showing MIDI Notes Being Played While in MIDI Editor Window? ianbee Pro Tools 10 12 10-12-2016 06:39 AM
Notes played in Midi Editor Nullifer Pro Tools M-Powered (Win) 2 04-01-2011 02:04 PM
PT8: Copying notes between tracks in Midi Editor? dennismil Pro Tools M-Powered (Win) 5 09-20-2010 11:59 AM
mass select of notes in midi editor stainless MIDI 4 08-20-2010 08:00 PM
