Old 09-15-2008, 09:06 AM
Gothboy's Avatar
Gothboy Gothboy is offline
Default Lost Communication with "Save Copy to"
Everytime I use "Save Copy To" to make a session backup to my external drive I get this:
"Lost communication with the audio interface. Please try increasing H/W buffer size or removing some plugins and make sure you have a valid clock source. Press OK to reset device. (-6097)"
I want to figure this out before I work on another session as it's become pretty annoying. My cpu meter is about halfway and plugin count isn't high. DAE Playback buffer is set at Level 2(default) and H/W buffer size is at1024 samples since I was in the mixing stage. Does this affect the backup in any way and why does this happen(aside from the obvious reasons implied in the error window)?
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core
16 GB RAM
Mountain Lion 10.8.5/El Capitan 10.11
Focusrite Saffire Pro 40
Ableton Live 10/Presonus Studio 3
Old 09-15-2008, 10:43 AM
Default Re: Lost Communication with "Save Copy to"
I'm no expert here but any time I see a "lost communication" message with a DIGI 002, I suspect the power harness issue. Also, how much free space is available on your audio drive?
Old 09-15-2008, 10:46 AM
Slim Shady Slim Shady is offline
Dual 1.4 processor G4 1.25GB RAM
Is this a "Mirror Drive Door" G4? If so, they have known issues with their firewire bus. It's recommended that you get a PCI firewire card to use with that computer as otherwise you'll get frequent firewire issues.
Read the bottom portion of this page.
Old 09-16-2008, 10:05 AM
Gothboy's Avatar
Originally Posted by albee1952 View Post
I'm no expert here but any time I see a "lost communication" message with a DIGI 002,I suspect the power harness issue.
This is one of the 002R revisions that were put out that were free of that issue. That's why I bought this one.
Tons. A 250 GB drive with 217 available at present. But, I'm backing up to a different drive, a 160 GB drive with tons of space also.
It's not a MDD Mac, it's a Sawtooth Gigabit ethernet with a processor upgrade. I DO have a Firewire PCI though...one of those combos with 3 usbs/2firewire ports. Should I try using that for the backup instead of the native port or is that stricktly and issue with the MDD?
16 GB RAM
Old 12-05-2008, 01:51 PM
Gothboy's Avatar
Since I'm getting nowhere with this and the problem persists I'm revising this post. Is there any way to remedy this as it's starting to get annoying. If I get this "Loss of Communication" error does it mean that some files don't back up? I'm always afraid of somehow losing data on the backup because of this.
16 GB RAM
Old 12-05-2008, 02:35 PM
DigiTechSupt's Avatar
Which firewire port do you have the 002 and/or any firewire drives connected to? Have you tried switching ports at all?
Avid Audio Tech Support
Support FAQ
Old 12-05-2008, 02:38 PM
Gothboy's Avatar
I have the 002R in native port 1 and the backup drive in port 2. I haven't tried switching ports.
16 GB RAM
Old 12-05-2008, 02:52 PM
Is that backup drive on port 2 on the computer, or the card?
Can you try connecting the drive to the card and let us know if anything changes?
Support FAQ
Old 12-05-2008, 03:27 PM
Gothboy's Avatar
It's on the computers' native port 2...not the card.
I will....I'll try it on the PCI in a bit. Thanks for the help.
16 GB RAM
Old 12-05-2008, 05:40 PM
Gothboy's Avatar
So I switched the port on the backup drive from the native 2 to the PCI 1 and didn't get the error on the first "Save copy to".....but, It also managed to not get the error once this afternoon before I switched ports....so I'll be watching this and post again if it comes up. My question is: Why does this have anything to do with the 002R? Why should the rack lose connection when the info is coming out of the computer from another firewire port?
16 GB RAM
PT's 10 Crashes when performing "Save Copy In" function soundguy69 macOS 2 07-07-2015 10:01 PM
PT10 : Volume automation disabled after "Save copy In" brenny Pro Tools 10 2 06-18-2015 02:33 AM
"Save copy in..." function copies files that have been cleared from session. ragbor Pro Tools TDM Systems (Mac) 7 02-08-2010 12:25 PM
"save session copy in" audio file name shortening simonchase Pro Tools TDM Systems (Mac) 2 05-10-2002 04:39 AM
"Save Session Copy" MUST copy AIIFF files??? BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-11-2001 12:33 AM
