Old 03-15-2006, 04:52 PM
Garissimo Garissimo is offline
Default Standalone CoreAudio Driver for Tiger has issues
Using Standalone driver version 7.0 on OSX 10.4.5 with 002r, iMAC G5 rev. A. Pro Tools is not installed. I'm using the 002r as a generic audio interface for iTunes, GarageBand, etc.
Two issues:
1) Shrill high pitched noise after playing iTunes for several hours continuously. Happens for no apparent reason. Killing and resetting the CoreAudio driver fixes it. I've had this problem with virtually every version of the CoreAudio driver.
2) CoreAudio driver will not connect to 002r after coming out of sleep. When the driver is in this mode, GarageBand throws error 25974, if that helps. This one is also random as it does connect most of the time. When this error occurs, the driver appears to get into a state of confusion where it refuses to let anything talk to the 002r. Power cycling the 002r and restarting the driver have no effect. This fault requires a full OSX reboot to fix. Extremely irritating.
Any ideas?
Old 03-15-2006, 09:15 PM
LaForestPoetry18 LaForestPoetry18 is offline
Default Re: Standalone CoreAudio Driver for Tiger has issues
Quote:"CoreAudio driver will not connect to 002r after coming out of sleep."
Your system needs to be set-up correctly, point being... "sleep-mode" is not a option. Set your system up step by step, as Digi gives guidence. Software is not perfect and dose have glicthes abound, but you have to help limit those by setting your computer up correct out of the gate.
If you have any futhur questions, hit me up at:
[email protected]
Power Mac Dual-core 2.0GHz G5, 2.5Gig if RAM
20" Cinema Display
160GB external HD
ProTools LE M Box 2
ProTools 7.1
LIVE 5
Reason 3.0
Garageband 2.2
KORG microKONTROL
Roland DM-10 monitors
BehrINGer Thruth monitors
AKG 270 headphones
BehrINGer B-1 condensor mic
Monster Power 2500 surge-protector
Old 03-15-2006, 11:08 PM
[email protected]
Laforest,
I appreciate your reply but for Digi's driver not to be able to recover from sleep mode is ridiculous. Sleeping your computer is a very normal function. Every other single piece of software and every other driver I have on my system comes out of sleep mode fine.
Just so that I'm very clear, restarting the CoreAudio driver *usually* restores communications with the 002r after coming out of sleep mode. When a restart does not work, the driver throws the error code 25974. This is a very specific error mode with a very specific error code and something Digi should be able to address.
Let me put it this way...you've come out of sleep mode, you've recycled power on the 002r and then completely killed your Core Audio driver and restarted it again. There is nothing connected to your CoreAudio driver. No iTunes, No Garageband, nothing. Still the CoreAudio driver can't connect to the 002r. This tells me it still has a "memory" of an application connected to it before the computer was put to sleep.
Old 03-16-2006, 11:48 AM
lwilliam lwilliam is offline
I don't recall a time when PT DID support sleep mode. It's always one of the first things you turn off on a new Mac when you use it with audio cards.
M-Audio also recommends that the sleep function be turned off, so it's not just Digi drivers.
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 03-16-2006, 12:51 PM
The Pro Tools application does not support sleep mode and that's understandable. The standalone CoreAudio driver, however, should be able to recover gracefully from sleep mode. All my other firewire devices come out of sleep mode without requiring an OSX reboot.
I'm not a newbie to the 002r, to OSX and audio recording in general and I'm not asking for a miracle here. I'm asking for a *very* reasonable standard of quality a general purpose audio driver such as Digi's should be able to provide. I'm not doing anything exotic with my system, yet I'm constantly having to work around the shortcomings in this standalone CoreAudio driver. It's getting rather frustrating.
Old 03-17-2006, 10:36 PM
NotRude NotRude is offline
There are a lot of little issues that bewcome very big (ANNOYING) with CoreAudio even 7.1, I have CoreAudio prevent PT from launching, it should actually turn itself off when PT is launched it it was intelligent, but it's a dumb application. Mine doensn't always launch when it's supposed to, will fail to quit and will not respond to force quit and will make other applications crazy. My old 6.9 would make iMovie crazy upon launch. I should consider myself lucky I guess, no hipitch sound or anything of the sort (hmm maybe its there and I cant hear it anymore) but you are absolutely right, the application leaves a lot to be desired
CoreAudio Manager/Standalone Driver for Tiger, Kernel Panic when launched Dustin Coffey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-29-2012 06:04 PM
Standalone CoreAudio Driver for Tiger Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 78 01-11-2007 10:26 AM
Standalone CoreAudio Driver (Tiger) can't see 002R Jon B Gamble 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-11-2005 04:22 PM
Standalone CoreAudio Driver for Tiger Avid Pro Tools TDM Systems (Mac) 0 09-02-2005 07:21 PM
Standalone CoreAudio Driver for Tiger Avid General 0 09-02-2005 07:12 PM
