Old 01-05-2011, 10:30 PM
mattrixx mattrixx is offline
Default 003R PT9 MacPro problem
Ok, so I've returned from holidays and the 003R will not work anymore.
It powers up, is recognised by the system (MacOSX.6.5), ProTools 9 is working with my RME FF800 (with no issues).
However, when I switch over to the 003R, it will not work and crashes PT9.
I've been through all the regular trouble shooting procedures and re-installed the PT9 CoreAudio drivers, 9.0.1 etc etc...
The 003R is not available in the AudioMidi setup for Core Audio.
I just keep getting DAE error -10.
Searching the AVID knowledge base revealed that there doesn't seem to be any knowledge about DAE errors, so I can't check to see what -10 is.
Note: The 003R is available in the presented hardware list when holding the 'N' on launch. When selected, the app takes an eternity to finish loading. I am then given the session loading window...... then 'Cannot communicate with the 003...." crash!!
So to summ up, PT9 is working well for me, except that I cannot use the Digi hardware. WTF!?
Update: Further investigation reveals that it might be a conflict with the latest FF800 RME driver. If I have the FF800 completely turned off, I can get things working.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 01-06-2011, 02:29 PM
Default Re: 003R PT9 MacPro problem
I wish Digi would release an actual (conforming to the spec) Core Audio Driver.
Matt McKenzie-Smith
mattrixx.net
Old 01-09-2011, 07:03 AM
youbringmesuffering youbringmesuffering is offline
there is a driver update for PT9 for the 003. not sure if that will solve your problem.
Jose
Old 01-09-2011, 03:11 PM
Unfortunately, it did not help.
Matt McKenzie-Smith
mattrixx.net
Problem to conect Artist Mix with MacPro PavelKalina Artist Series 1 11-29-2012 12:51 PM
Westmere MacPro & Digi 003R Brian in Charlotte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-10-2010 06:56 PM
Is there a problem with the 003R ? MrBlack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-02-2009 02:59 PM
Problem with 003r seraph_signum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-20-2009 10:21 AM
pro tools 7.1.1 on macpro 10.4.9 combo + 002 = problem ayahuasca 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 05-06-2007 03:06 AM
