#21
Re: AVID CORE audio manager Problem
I'm running 10.10.5 and core audio manager does not work at all.
#22
http://avid.force.com/pkb/articles/r...er-v12-3-Notes
"Avid will enable audio streaming for iTunes, Flash and 3rd-party DAWs with an upcoming HD driver update. The following issues will be fixed with the upcoming release: iTunes doesn’t work with HDX and HD Native interfaces on OS X 10.10 and OS X 10.11. Avid CoreAudio Manager breaks Native Instruments products on OS X 10.10 and 10.11. Restart/Shutdown is prevented by CoreAudio component of the HD driver installed. " Thank god.
MacBook Pro 2018
Pro Tools Ultimate 2023.9 EuControl 2023.11 Avid Control App 2023.11 HD Native Thunderbolt HD I/O + Omni Avid S1 x 2 |
#23
I hope the fix is not "Coming Soon".
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps. |
#24
Yosemite 10.10.5 PT 12.3 . No core audio and won't allow installation of HD Driver 12.2
Need a fix soon . I use Cubase, Logic and Wavelab . PT was a clean install after buying an HDX card so I have no previous version . I'm just stuck |
#25
update : Cubase works fine with Asio driver . Logic loads the core audio driver but you have to match the buffer on the "core audio driver" and in logic . It won't do it alone and if there is a mismatch Logic will wrongly interpret the sample rate . For ex I had 128 in Logic and 256 on the core audio driver ( that you can't change) and Logic said "22khz sample rate detected"
#26
I skipped the 12.3 HD Driver and went right to 12.4 HD Driver, but the Mac 10.10.5 Core Audio STILL does not "auto-launch" the AVID Coreaudio Manager with HD Native / HD Omni, nor HDX Systems!
Brian Dozoretz ACSR ACI Dolby Atmos Mac Pro, os12.6.3, PT 22.12 HDX, 2xAlphalink,1xDeltaLink, Mac Mini, os12.6.3, PT 22.12 HD Native + HD Omni, Artist Series Mix x 2, Artist Series MC Transport, Atmos 5.1.4 VENUE SC48 3.2 with iPad Control SSL Duality SSL Duality via ipMIDI / ∂elta Automation Plug-In |
#27
hi Brian,
tnx for the update. Can you manually launch the Avid Core Audio Manager and does it work, i.e. can you play sound from Logic/iTunes/etc., through your HDX? cheers rgds Dave Last edited by davemurphy; 01-27-2016 at 12:56 PM. |
#28
I can manually launch, and "Pro Applications" can access the HDX Hardware via their own Audio Preferences.
"Host" Applications, such as iTunes, Spotify, Safari, etc. that rely on Apple's Audio MIDI Setup / System Preferences>Sound ONLY see HDX as a "Valid" OUTPUT Device. The INPUT side does not see ANY HDX option, and thus Apple's core audio will not allow it to be used as a valid device.
#29
hi Brian,
thanks for the udpate. At least you have sound out, which is a step forward. Are you still running MacOS 10.10.5 or have you upgraded? cheers rgds Dave |
#30
Actually, there is no change is the AVID Core Audio Manager since Pro Tools 11 on any of my systems.
The wording of 12.3 HD Driver makes it sound like they "finally" got it to work, but unless someone is having success on El Capitan, it seems they still need to tweak this.
Avid Core Audio Manager don't change the Sample Rate | catuser | Pro Tools 11 | 0 | 04-22-2014 11:48 AM |
002 pro tools 10.3.5 Avid Core Audio Manager not working with safari or iTunes? | nate9 | FireWire & USB Audio Interfaces (Mac) | 1 | 07-19-2013 07:25 AM |
Digi Core Audio Manager problem | Ben Jenssen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-20-2009 07:08 PM |
Digi Core Audio Manager problem. | spaceagedevice | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-06-2006 05:59 PM |
Digi Core audio Manager Problem!! out 1&2 or 1&5! | Mark 66 | Post - Surround - Video | 0 | 02-06-2005 11:09 PM |
