Old 03-15-2014, 06:35 AM
bblair bblair is offline
Default PT11 HD and non-HD on same machine?
I want to be able to run PT11 HD Native via Thunderbolt from my mac mini. I require HD because I need surround mixing capability.
I'd also like to be able to leave the thunderbolt interface at the studio and take just my mac mini home using the built in output.
My understanding is that HD will not work without either the HDX Native pci card or the Native Thunderbolt interface connected. Is that correct? If so, then I would also need the non-HD version of Pro Tools for mobility.
Can HD and non-HD be installed on the same machine?
Or am I incorrect in my understanding that HD software requires Avid hardware?
Old 03-15-2014, 06:52 AM
Default Re: PT11 HD and non-HD on same machine?
The software is the same in all installations. Its the iLok asset that tells Pro Tools whether to open as HD or non-HD. As long as your iLok has the HD asset on it, Pro Tools will open with all HD features, with the exception of DSP(no HDX cards=no DSP) and you will be limited on inputs(32 with native hdwr, 64 with an HD/Native card).
Old 03-15-2014, 07:41 AM
Awesome, thanks for the quick response.
So, if I have the HD ilok asset, my pro tools software will have surround capability, even if I don't have the native thunderbolt interface attached?
Old 03-15-2014, 07:50 AM
nst7 nst7 is offline
That is correct.
Since you'll only be using the Mac's built in output, which is just stereo, you'll want to use the Avid Downmixer plugin to fold the surround channels down to a stereo mix, so you can hear everything.''
The Downmixer plugin is included with the software. However, it does not work on a master fader, I think it's only on audio or aux tracks.
Old 03-15-2014, 07:53 AM
That's great news! Thanks to all for your help.
New PT11 install Machine Control problemnotification TomLewis macOS 1 12-15-2013 01:23 PM
PT11 HDX 9-Pin Machine Control - greyed out timothyd4y Post - Surround - Video 1 11-15-2013 07:40 AM
HDX/PT11 and HD2/PT10 same machine? rockridge98 Pro Tools HDX & HD Native Systems (Mac) 2 11-10-2013 06:48 AM
Possible to have 10.3.6 TDM and PT11 native on same machine? mtung Pro Tools 11 4 07-27-2013 07:11 PM
Will PT11 Run on my Machine? (Sandra Report Attached) SixBladeKnife Windows 5 06-25-2013 11:49 AM
