Old 05-31-2023, 02:29 PM
livstone livstone is offline
Default Trouble using Mackie Control Universal in Pro Tools 10
I am having some issues using my Mackie Control Universal in my Pro Tools 10HD system. I set up this system over the last couple of years moving up from a Mix24 system on a G4. When my Stealth serial port went bad I figured it was time to move up a bit and bought a 2010 Mac Pro and some Pro Tools 192 Interfaces along with Avid Midi I/O the HD cards.
After setting up everything I seem to be having only partial communication with the Mackie Control Universal. I am able to start and stop and get the time info so the right side with the transport controls work but all of the fader section is not communicating at all. I get no movement or control and no mute, pan or display info above the faders section.
I tried the MCU on a friends system and it worked perfectly on his older system with no issues. I then tried different midi cables and that did not fix the issue.
Does any one have any idea what I may be missing to set this up properly?
Thanks
Old 06-02-2023, 08:19 AM
Default Re: Trouble using Mackie Control Universal in Pro Tools 10
I might be wrong, but I thought Pro Tools only worked with Eucon and HUI, but not MCU?
Old 06-02-2023, 11:38 AM
smurfyou smurfyou is offline
The MCU has a HUI mode.
~Will
Old 06-04-2023, 11:33 AM
Yes it does use HUI mode and that's what is set in the Pro Tools prefs.
Old 06-04-2023, 11:45 AM
Can you detail what you have set in Peripherals->MIDI Controllers?
~Will
Mackie Control Universal Pro/Extender with Pro tools 10 Issues. Tonato17 Pro Tools 10 6 04-07-2014 12:27 PM
BCF2000 with Mackie Universal Control on Pro Tools 10? jakedavis Pro Tools 10 5 01-04-2013 08:20 AM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
Mackie Control Universal??? sethbrand Pro Tools M-Powered (Mac) 1 04-17-2007 04:07 PM
mackie universal control with pro tools 6.2.3 muscmp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-26-2004 10:35 AM
