Re: Solution to the error -9514 on Windows 8 (memory / cache / DAE buffer)
Shane, THANK YOU! IT WORKED!!! Now, may I ask "WHY" it worked and what the heck I just did??? :) No SQL expert at all. But I assume this has something to do with some aspect of a SQL engine??? Now, I just did this using 10.3.1. Should I leave that alone and not worry about 10.3.3 at all at this point or do you think this will carry over to it if I try to go back to the latest ver?
Hopefully I won't have any further issues.... THANKS!!!! |
Glad to hear it worked. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
That is the one of the privileges installer sets up which naturally needs some tweak in Win 8.
:: Bharath Pro Tools Software Team |
Thanks guys so very much. I'm back in business! And I did apply the 10.3.4 upgrade and it worked fine with no hitch. Hopefully will not have any further issues.
I'm also looking forward to the true 64bit version some day. Hopefully that's in the works! All my best and thanks again! Isaac |
Now would be the time to heed Albee's advice....BACK UP!
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Trust me... System has been imaged since I have everything now operational, plus a full backup :)
Thank you! |
Wrestled for 2 days and the answer was: Just Reinstall Avid HD Driver x64 after PT is done installing.
Go to your protools install folder and navigate to the ISSetupPrerequisites folder. C:\Pro Tools Avid Pro Tools HD 10.3.2 Windows\Pro Tools Installer\ISSetupPrerequisites\Avid HD Driver x64 Click the Avid HD Driver x64 Folder Run the installer as admin Now in: C:\Program Files (x86)\Avid\Pro Tools Right Click the ProTools.exe App and choose "Properties" Select to launch ProTools.exe in compatibility mode for Win7 Select to launch ProTools.exe as admin Relaunch ProTools.. Voila!! |
Could not allocate memory for the disk cache. Try lowering your disk buffer.. | slim_shady | Pro Tools 10 | 15 | 05-09-2017 05:20 PM |
DAE buffer -9514 error | jonwade92 | Windows | 14 | 08-01-2013 12:16 PM |
-9514 Disk Cache Error | wackjaw | Windows | 4 | 06-18-2013 08:42 PM |
Pro Tools 10 on Windows 8 (error 9514) | [email protected] | Windows | 9 | 11-08-2012 01:32 PM |
Pro Tools 10 Launch Error (-9514) "Disk Cache (DAE)..." | mgthefuture | Pro Tools 10 | 5 | 03-03-2012 09:59 PM |
