  #21
Old 12-01-2021, 04:24 AM
tonwurm's Avatar
tonwurm tonwurm is online now
Default Re: Any benefit to TDM in 2021?
Originally Posted by jfreak View Post
correct. Tdm cards never made it to 64bit, so you would need to be using pt10 or lower, which means mountain lion or older (though mavericks works with known issues).
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
  #22
Old 12-01-2021, 05:35 AM
DimitriFP DimitriFP is offline
Originally Posted by tonwurm View Post
I didn´t try this, since I assumed it won´t work or not reliable at least. I use the RME Interface in Catalina only. Did also work very reliable in High Sierra and in Mojave.
With dedicated SSD´s for both Catalina and Mavericks, to boot up the other system is only a thing from a minute to switch between tracking and mixing. For fast recordings during the mix process I have connect Microphon Cables to the RME. Externeal Gear, f.e. synths I record via the RME, too.
But the zero-latency tracking under PT10 in Mavericks is for me still the perfect way to do long recording sessions or to record a complete band.
Thank you, that info finally settles the score :)
Now that the above is established, I would assume that not all versions of PT Ultimate would install in High Sierra ?
I'm looking into buying a perpetual Ultimate license, but assume the installer I'll get delivered will be too new to install on High Sierra.
Also knowing Avid, I very much doubt I can get older installers from them...
Any suggestions here ?
Dimitri
www.dimitrifromparis.com
System:
MacPro 5.1 2x3.46 Ghz 6 Core 48gb ram MacOS 10.9.5
PT 10HD + PT11
HD Core PCIe + HD Accel x2
Digidesign 192 IO (Blue)
  #23
Old 12-01-2021, 05:37 AM
JFreak JFreak is online now
Perpetual license holders can use any version since PT12.6 which is supported on Sierra. Highest version supported on High Sierra would be PT2020.12
Avid Download Center is your friend here, not only Avid Account that has the latest.
  #24
Old 12-01-2021, 06:08 AM
That made my day, after several of being lost THANK YOU !
I'll allow myself to keep asking til you're bored answering:)
Are there later "unsupported" Ultimate versions that can be installed - and are worth doing so - in High Sierra ?
I was particularly interested in the delay compensation of side chain paths which I believe only got introduced not that long ago...
Dimitri
System:
PT 10HD + PT11
  #25
Old 12-01-2021, 06:11 AM
You can always try. Unsupported does not mean not working. It is just unsupported, Avid first asks you to upgrade your OS.
  #26
Old 12-01-2021, 06:15 AM
Yes, it was version 2021.6 if I remember it right
  #27
Old 12-01-2021, 06:38 AM
will try that one indeed !
last question of the day, just in case, although it further out of the topic as it goes
Couldn't find the info on the crossgrade plans
Would you know if surrendering a PT11 license that was bundled with a PT10HD one would mean surrendering both 11 AND 10 ?
Any way to know wether my 10 and 11 where actually a bundle ?
They do show as 2 separate tabs in the "My products" section.
Also 10 and 11 licenses reside on 2 different iLoks but I remember getting them at same time...
Dimitri
System:
PT 10HD + PT11
  #28
Old 12-01-2021, 06:42 AM
I don't really know about Avid policies but I would think if you have a license bundle, the new one would have the same licenses added with new one(s).
What I would suggest is wait a little and see if Avid comes up with suitable promotion for the end of the year. December seems to be a bad idea to buy anything in normal price.
With that said Avid front page has "save UP TO 50% off" deal for new subscribers. That will however not help you, so wait for the next deal.
  #29
Old 12-01-2021, 07:13 AM
Yes, waiting for the next promotions seems very wise advice thanks !
I see there is a 30 Ultimate trial offer, hopefully that would authorise any ultimate version, so I can at least make sure what which work in High Sierra
Dimitri
System:
PT 10HD + PT11
  #30
Old 12-03-2021, 04:55 AM
I´m running a dual boot system on a Mac 4,1 (firmware 5,1) ... one partition (Mac OS 10.9 Mavericks) PT10 TDM HD3 for tracking, the other partition (Mac OS 10.13 High Sierra) for mixing on PT Ultimate ... PERFECT
@tonwurm @JFreak
Back with a few more questions :)
I've created a High Sierra boot on my MacPro 5.1 and I can now boot either in 10.9.5 to open old PTHD10 TDM session, and in 10.13.6 for a not yet installed newer version of PT
For the record, PT 11 does launch seemingly OK on High Sierra, although I didn't fiddle much to check stability - It's "unsupported" by AVID in any case
I was wondering if there was a core audio driver that would let me connect via the old accel card to the blue 192 Audio interface, not for PT but for other DAWs such as Ableton.
In 10.9.5, although PT11 doesn't "see" the 192 (as established in several threads) Ableton Live 9 64bit DOES connect seamlessly to it via Core Audio.
I've read somewhere that old PT9 drivers were working at least in Mac OS 10.11 El Capitan.
Thank you
Dimitri
System:
PT 10HD + PT11
Pro Tools 2021 with 2 iLok authorizations for Renewals & Subscriptions unkJE General Discussion 2 07-06-2021 08:07 PM
2021 Scorch still being updated?? Carl393 Avid Scorch (iOS) Forum 6 04-29-2021 12:43 PM
What is in store for PT in 2021? Dave S. General Discussion 7 01-26-2021 01:10 PM
NAMM Believe In Music 2021 Avid General 2 01-21-2021 09:31 AM
Avid announces Pro Tools 2020, 2021 and 2022! off the wall Pro Tools 2018 2 04-01-2019 08:50 AM
