Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 04-16-2020, 01:30 PM
pedjababic pedjababic is offline
Default mac os catalina 10.15.3
anyone with the installer of catalina 10.15.3 ?
accidently updated to catalina 10.15.4... trying to downgrade to the right macos.
could my prottols work in 10.15.4 ?
Old 04-18-2020, 11:49 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default Re: mac os catalina 10.15.3
10.15.4 is working for me on my MacBook Pro.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 04-18-2020, 12:28 PM
JFreak's Avatar
JFreak JFreak is online now
Same here on Mac Pro, and if you are doing a clean install I would actually advise you do the 10.15.4 update because that allows you to use your iCloud plan as "dropbox". Been very good here actually (the 10.15.4 & 2020.3 combo)
Janne
Old 04-18-2020, 02:21 PM
Macsearcher Macsearcher is offline
I know that there is lots of info about Catalina out there but I'm a bit overwhelmed with it all. Is there a post here (or can someone on this thread help out) with a summed-up answer for the pros and cons of upgrading to Catalina. I'm currently on Mojave.
Old 04-18-2020, 02:25 PM
JFreak's Avatar
Simply put now that I have those iCloud folders to share, would not want to live without. Also seems to run better than Mojave so better compare to High Sierra if you want to something older.
Janne
Old 04-18-2020, 02:28 PM
Thanks JFreak.
I have Mojave on my laptop which I use mostly for non-music related tasks but I do run Pt sometimes on it while I'm away from home.
My main studio computer is High Sierra and I'm most afraid of updating that one.
Nervous about compatibility with other software, UAD, Waves, NI etc.. just wondering of there is some kind of master list of Catalina compatibility.
Old 04-18-2020, 02:29 PM
JFreak's Avatar
Keep your studio computer in High Sierra and test Catalina on your laptop? Just do a clean install to empty system drive, upgrade install does not work very well.
Janne
Old 04-18-2020, 02:32 PM
Thanks JFreak. Clean install to a system drive is a bit daunting for me on the laptop as I only have the one drive. How would you go about doing that? I'm a bit locked down here so getting an external drive right now is a bit of an issue.
Old 04-18-2020, 02:33 PM
JFreak's Avatar
Well obviously you need some place to keep your stuff while you are rebuilding the system. Maybe you need to wait until you get a drive that you can use?
Janne
Old 04-18-2020, 02:36 PM
Sounds like it.
If it's not too much trouble, assuming that I can find an external to use... could you lay out the steps for me?
I'm assuming that I'd clone my main drive, create a blank partition on a new drive, install Catalina, but how do I get all of my prefs etc. back? Sounds a bit painful.
HDX in new Mac Pro/Catalina rourketown Pro Tools 2019 11 08-24-2020 03:40 AM
HDX on Catalina drums77 Pro Tools HDX & HD Native Systems (Mac) 4 04-02-2020 05:52 PM
Catalina on Mac Pro 5,1 the.engineer macOS 15 01-24-2020 06:06 PM
PT and Catalina gub macOS 3 12-21-2019 12:48 AM
Catalina Ryan Young Pro Tools 2019 6 06-06-2019 10:20 PM
