ADC Lesson
Hey guys, Im going to tackle learning my way around this issue so I can use my Protools LE 8 more often.
1. TRACKS= Shift them back by the delay shown a the bottom of the track 2. BUSSES ?? 3. AUX SENDS ?? 4. Master buss? Etc I DONT want to use any of the time adjusters if I dont have to. I want to manually learn how to do this first Thanks
MacPro 8 Core,2.4, 14 Gig Ram. OSX 10.8.2 |
Re: ADC Lesson
What plugs are u using... I mean, I realllly do not ever have a problem with latency...
Re: ADC Lesson
WAVES Gold, Musicians Bundles and the stock DIGI stuff.
I just need to know how here in case I do if you know what I mean
Re: ADC Lesson
I gotcha'... Well yeah, duplicate the track, & shift as needed... U can hit alt+H to shift...
Re: ADC Lesson
WHat about number 2,3,and 4?
Re: ADC Lesson
Using time adjuster IS the manual way to do it.. If you were going to adjust everything just by shifting, then I would think you would have to wait until you have ALL your plugs, tracks, auxes, decided. Then figure everything out. Then, when you decide you need to change a plug somewhere you're screwed, because you don't know where everything WAS.. So here is the way to do it using time adjuster... http://www.screencast.com/users/peed...ders/tutorials
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Re: ADC Lesson
Nudging is a bad idea.
As flommer said, change a plug-in and you are screwed. Change your playback engine and you could be screwed, too. Time Adjuster is manual.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Re: ADC Lesson
A little experimentation will show you which plugins cause latency. Many of them do not. I have used PT for 5 years and almost never have any issues with latency. I leave plugins off the master(I do that as a separate step in a separate session or in WaveLab). The worst plugins will be anything that is "look ahead" like any mastering/brickwall limiter or a gate that claims zero attack time. I use buss compression with drums(parallel compression) with BF76 and Waves SSL buss compressor all the time with zero phasing issue.
Re: ADC Lesson
Or buy mellowmuse ata. With a little settin' up, it will do it for you.
TD
my blog:Tamas Dragon |
Re: ADC Lesson
^^^yeahppp^^^
Just learned another new, expensive lesson | Pred80r | Pro Tools TDM Systems (Mac) | 11 | 12-30-2009 10:40 AM |
Let this be a lesson to you kids out there! | Wango | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-04-2009 06:12 AM |
A lesson learned from the pro's at DUC | randyT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-04-2005 09:21 AM |
Latency lesson needed? | AudioArtCafe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-09-2004 07:48 AM |
balanced, unbalanced -- I need a lesson | Joseph Grimm | Tips & Tricks | 2 | 04-30-2001 02:23 AM |
