How do I send stereo audio out the Optical out (enc) on 192????
Greetings,
I have read through as many posts as I could find on this... I currently have mac audio routed out the mac's optical port into the spdif optical port on the 192 (the "encl" one). This works. So, I have all mac audio routed into an aux channel. I am now trying to figure out how to get sound from protools out through the spdif optical port (again, the "encl" one) into the mac's optical input. I do not understand how I select the "encl" optical out port. In Digital Format I have Optical selected. On the input side, 15-16 says Opt(S/PDIF). On the output side it says Dgtl78(lfr) - and Digital Enc option is grayed out. I also checked the AMS setup and the Digital In says "locked" on the clock (sample rate/bit depth are all the same). I know that the optical in on the mac is working fine because I can send it stereo audio and have it play back through my "mac audio" aux channel (side not - I have to use Audio Hijack to grab the incoming signal and route it back out of the mac). When I unplug from that optical source and plug into the 192... I get nothing. But, I am not even sure I have it set up correctly since I can't seem to select the "enc" output - and therefore I have no way of knowing if I am really sending anything out that "enc" port. Sigh, if I get this working, I will be ecstatic. I am attempting to use Pro Tools as a "mixing board" in conjunction with Ableton Live on the same machine. So, audio routed into Pro Tools goes out the "enc" optical port, into the mac, into a channel in Live, which then goes out the mac optical output into the 192 "enc" optical input for monitoring in Pro Tools. Why am I doing this? Because Rewire only sends audio one way and I want to be able to use the plugins (like eleven) in PT, but record and arrange in Live. Thanks, Jared |
Re: How do I send stereo audio out the Optical out (enc) on 192????
in the 'Hardware Setup' under the tab 'Main' the default settings for 'Output 1-2' is 'Analog 1-2'
with the control key pressed (on Mac, Windows don´t know) klick the 'Output 1-2' selector and choose 'Digital [Enc]' after that you can see in the 'Output 1-2' Selector that it has changed to '+Analg 1-2', which means that both Analog and Digital Out are active hope that helps
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
Figured it out (this dog couldn't walk from the hunt). I had Out 1-2 assigned to Analog 1-2 AND Digital Enc. I finally clued in to the + next to the assignment. Selected only Analog 1-2 and voila, Digital Enc finally showed up as an option for 15-16. It works! Now I can record guitar through Eleven into Live (and use the RTAS instruments!).
Thanks, Jared |
PT9 - can it send an AC3 or DTS out the Mac optical output? | Farmer Dave | macOS | 11 | 06-12-2011 10:09 PM |
Can you send 5.1 Blu-Ray/DVD optical out into Pro Tools 192 IO? | ncaoili | Post - Surround - Video | 7 | 01-19-2010 11:54 AM |
copy a send (w/send level intact) from 1 to 30 audio tracks? | MixerGuy | Pro Tools TDM Systems (Mac) | 3 | 12-30-2007 03:20 PM |
Mono to stereo send | davetron5000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-28-2003 07:43 AM |
How can I send the stereo bus out to my Apogee and then back into PT? | ixnys | Tips & Tricks | 5 | 08-13-2003 03:20 AM |
