Virtual Instrument Track
hi
I am having a little bit of trouble trying to setup an instrument track for recording, pretty much I opened an stereo instrument track and insert strike on it, select the patch and start to play, I can hear everything. Also armed and start to record, I see the signal of the instrument track and hear everything, once I finish to record and try to listen to the recorded content I don't hear anything, output selected correctly, in the region list a see only a blue color but not content, I should see all MIDI content in there, looks like strike is not sending any midi content. If I insert any other V.I and start to record, I am able to play it back, I see the midi content, but not with Strike. Anyone know if there is any specific configuration that I need to do? thanks Last edited by marcioguitar; 01-08-2009 at 08:06 PM. Reason: adding more information |
Re: Virtual Instrument Track
filosofem |
I have a controller and everything, but there is no print in the edit window, even in recording mode, I see audio going thru the instrument track but its not printing midi data, since its happening only when I use Strike, I think its related to midi channels inside the plugin but I have no idea how to figure it out.
I believe PT has a feature that allows any track that is selected to pass any MIDI input to the instrument on that track. It doesn't mean that there is actually MIDI being routed to the track though. You need to open the "Instrument" panel view, and make sure the MIDI data is triggering the MIDI meter (not the same as the audio meter). If not, you need to route your controller to your instrument manually.
Edit: Oh, and it probably has nothing to do with Strike, since MIDI goes to the track first, and THEN to the instrument on the track. |
If however you are using Strike in Kit Mode, you will need to assign the Instrument track MIDI Output to Strike Channel 2. filosofem |
A picture can speak a thousand words! (this one's moving too, so do the math)
http://airvirtualinstruments.blogspo...-sessions.html That should sort you out.
I work with amazing people who do incredible things. Founder of the Expert Sites. |
import midi file for virtual instrument track | butchhutch | Pro Tools SE and Essential (Win) | 0 | 08-25-2012 01:31 PM |
Virtual Instrument help! | madgt621 | Virtual Instruments | 2 | 04-06-2010 05:57 AM |
Mono Instrument Track VS Stereo Instrument Track | mbox2issue | Tips & Tricks | 8 | 04-20-2009 04:21 PM |
Lag when using virtual instrument... | onebigtrip | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-22-2008 10:47 AM |
virtual instrument midi track problem | acappellajosh | MIDI | 3 | 04-12-2006 09:53 AM |
