Old 02-13-2009, 05:51 PM
DaveSB DaveSB is offline
Default Digidesign 002R question
Hi if Pro Tools says it can find hardware is it likely to be power harness /power supply issue or mainboard.
Worse case how expensive is mainboard on Digi 002R to replace
thanks in advance
Dave
Old 02-13-2009, 06:33 PM
stainless stainless is offline
Default Re: Digidesign 002R question
I initially had a problem with my 002R, when launching PT my sample rate light would flicker and the mute light would be on and I couldn't turn it off- this was a power supply issue and my power supply was replace (and it was really easy)
no idea about the main board..... but I would wage you could buy another (used) 002R for the cost and hassle
have you tried cleaning (DeOxit) and resetting the molex connectors for the power supply?
I'd try this before considering a mainboard... and my understandiing is the PS issues showed up pretty quickly (hours of operation) and (apparently) never had issues... I call Digi and see if your serial number is one of the "known issue" units
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc
Old 02-13-2009, 07:17 PM
albee1952 albee1952 is online now
reseat each connector on the harness 5-6 times and odds are at least 50/50 that it will be back working.
Old 02-13-2009, 07:28 PM
ncj ncj is offline
Dave, did you change anything prior to it not being able to find the hardware? I don't know if this applies to you, but when I installed PTLE 8.0, I was prompted to update the firmware on my 002R. After that, Pro Tools could not find the hardware. Fortunately, re-installing Pro Tools fixed things.
Old 02-14-2009, 09:30 AM
Overlord of the Undertone Overlord of the Undertone is offline
I don't remember having to update the firmware in my 002R after installing PTLE8. How can I check that?
Old 02-14-2009, 01:00 PM
TOM@METRO's Avatar
No firmware updatefor me. Runs fine.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2021 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
FS: Digidesign 002R kiddakota Buy & Sell 0 07-29-2012 03:36 PM
livestream procast and digidesign 002r scubadrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-09-2009 06:32 AM
"Unable to locate Digidesign hardware" 002R 7.3.1cs4 mrblakemr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-15-2008 01:59 PM
002R, iTunes and Digidesign.com fenderguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-09-2006 09:37 PM
Digidesign ASIO driver does not work???? 002R muse6638 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-10-2004 03:31 PM
