Old 04-10-2004, 11:41 AM
muse6638 muse6638 is offline
Default Digidesign ASIO driver does not work???? 002R
Hello all,
I have problem getting Digidesign Asio driver working on certain software.
I tried everything from disabling onboard soundcard and running onboard soundcard and 002r running at same time. I do not know why 002R do not work on every software. For example, when I open up the quicktime or real player, my sound do not come out from 002 r. It goes to my onboard sound card, and if I turn off my onboard sound card, I do not hear anything. I tried everything from changing preferences or options from the software, but it does not help at all.
I am running 002 R with P4c800 E deluxe MOBO.
And here is the lists of software that I have problem with.
Quicktime player, realplayer, adobe dvd encore, adobe aftereffects, adobe premiere pro, soundforge, powerDVD and anysound that is coming from Internet Explorer.
Here is the lists of sotfware that works with 002 R.
Nuendo 2.1. Vegas 4.0, Windows Media player, adobe premiere pro, reason, and protools of course.
Plz help!!!!!!!!!!! Can't go to bed..
Ohh,, also,
plz tell me why I can't run 2 software at same time on 002 Rack.
For example, is there anyway I can use protools and Reason or Nuendo running at same time on my 002 R?
If it does not let me do that, how do i run Reason using rewire in Protools?
I am guessing that I won't hear anysound from reason while protool is running at same time???
Plz help!!!
Old 04-10-2004, 11:50 AM
Default Re: Digidesign ASIO driver does not work???? 002R
All the programs you listed don't support ASIO.. they require the WaveDriver.. which is a different animal.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-10-2004, 12:29 PM
Thanks for the reply!!!!!!!!! Rail,
Then is there anyway I can route the audio signal from those software to my 002R?
I use Adobe Encore DVD as my DVD authoring software. I finish all my surround mix using Nuendo and bring it into the Adobe Encore DVD. But, if I can't hear the surround mix from the Adobe Encore DVD using 002 Rack, it will be a big problem for me.
Ohh,, also,
NE1!!!!!!!!
plz explain me why I can't run 2 software at same time on 002 Rack.
Plz help!!!
Old 04-10-2004, 12:35 PM
If you have Pro Tools 6.1.1 then download and install the WaveDriver 6.1.1 and Digi MME Helper from the downloads section of this web site.
Install the WaveDriver and reboot.. and open MME Helper and drag the apps that aren't listed into the list and click Update.
Try loading the apps without Pro Tools running and assign your 002 as the playback device in the prefs.
The dalwdm.sys driver can only work with one app at a time - that's the way it's designed.
To use Reason while Pro Tools is open.. create a stereo aux track in pro Tools and instantiate the Reason ReWire plug-in.
Rail
Platinum Samples
Old 04-10-2004, 01:56 PM
Hey, Rail
I just installed wavedriver 6.1.1, rebooted and installed Digi MME helper.
I added adobe encore dvd and couple other softwares like quicktime and realplayer into MME helper and updated.
But, I still can hear audio through my 002 rack.
I totally followed ur instruction.
What could be the problem I am having??
I tried disable the onboard sound card just to be safe from conflict, but did not help.
I used to have tascam fw-1884 firewire audio interface with this computer and never had this kind of problem. I just exchanged to 002 rack, so that I can learn protools better and it seems like this unit is total headache so far.
Old 04-10-2004, 03:31 PM
WOW!!!!!!!!!!
Hey, Rail!!!!!!!!!!
My 002 rack start playing back sound from 3rd party softwares!!!!!!!!!!!!!
WOw, this is awesome software.
Thanks much to u, Rail!!!!!!!!
Now, I can go out with my wife for dinner!!!!!!!!!!!
Does anyone have an OS9 Digidesign asio driver...? adrian10 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-31-2014 12:37 PM
Digidesign Asio Driver Errors LoveLeMusiq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-01-2010 12:20 AM
Digidesign ASIO Driver w/o Protools LE? hanker09 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-12-2003 05:19 AM
Digidesign ASIO Driver for Windows XP Avid General 0 11-20-2002 03:43 PM
ASIO DigiDesign DirectIO "NEW" Driver? Kevan Staples General Discussion 1 12-07-1999 08:18 PM
