Old 03-15-2010, 07:44 AM
JoshuaD JoshuaD is offline
Default AMD vs Intel, does it matter?
Right now the AMD quad-core 2.5ghz processors are significantly less expensive than their intel counterparts.
AMD Total (2.66ghz)- $170: processor, Motherboard.
Intel Total (2.5ghz) - $260: Processor, Motherboard.
Is there a downside to using the AMD processor?
Does anyone know of a Socket AM3 motherboard with a compatible chip-set that has an on-board firewire slot?
Old 03-15-2010, 09:20 AM
Wavelabs Wavelabs is offline
Default Re: AMD vs Intel, does it matter?
Athlons are considered very slow and old CPU's.
Get a Phenom-II instead.
Actually, you can now get a AMD Phenom-II (3.4-Ghz) Processor for 189 dollars.
Thats 1-Ghz more you can have for the same amount of money.
SPEED BABY SPEED.....!!
http://www.newegg.com/Product/Produc...-727-_-Product
And as far as motherboards compatible and no problem boards here are 3 of the top of the line.
Get the - GigaByte GA-MA790FXT-UD5P
but if Newegg does not have it, then these are the next steps you should go with.
1.
http://www.newegg.com/Product/Produc...-416-_-Product
2.
http://www.newegg.com/Product/Produc...-427-_-Product
3.
http://www.newegg.com/Product/Produc...-415-_-Product
hope that helps
AMD Phenom II X4 940 w/ CoolerMaster V8 Cooler - GigaByte GA-MA790FXT-UD5P - ATI Radeon 6850x2 (x2) - Win7 x64-bit - AMS Venus-T5 with 1-TB x5 Drives
Kingston Hyper-X DDR3-1066 2gig x4 (8gig Ram) - WD SATA VelociRaptor 300 (x4) - XXXXXXXXXXXXXXXXXXXX - Groove Tubes GT-66 & 55 Microphones - BBE 422-A - Aphex 104 C2
Vantec MRK250ST w/ Win7 x64-bit (HotSwaped for ProTools v8.0.4 Unit) - Acer v223w (x2) LCD Screens - Events 20/20 - Avantones - Mackie HR824 - AKG P220 - HS50m's
Old 03-15-2010, 09:59 AM
TOM@METRO's Avatar
All that being said, Intel is currently the hands down favorite for use with native Pro Tools, see these threads for test results..
http://duc.digidesign.com/showthread.php?t=200560
http://duc.digidesign.com/showthread.php?t=238426
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2021 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-15-2010, 11:37 AM
You're the man Tom. This is exactly the sort of info I was looking for. Thanks.
Old 03-15-2010, 11:44 AM
I'm definitely going Quad-Core.
It looks like I can get a 3.5Ghz AMD chip or a 2.5Ghz Intel Chip for around the same price. Considering that Intel is the preferred chip for Protools, but that the AMD is 1GHZ faster, which do you think would be the better choice?
Old 03-15-2010, 12:09 PM
JoelG's Avatar
JoelG JoelG is offline
Intel are going to be a better chip at this point. AMD will be cheaper (and possibly a better price/performance). But, it's not all just more Ghz the better, check out the CPU charts here and compare. See which one has the best spec for the amount of money you want to pay. AMD MB's are usually a bit cheaper than Intel ones, and they seem to be upgradable for future CPU's better than an Intel platform.
http://www.tomshardware.com/charts/2...hmarks,60.html
All that said, if I were buying a new computer it would likely be an Intel at this point...
Joel
Old 03-15-2010, 04:27 PM
So here's an AMD build and an Intel build, any opinions?
Intel ($403):
Processor: Intel Core 2 Quad Q8300 Yorkfield 2.5GHz
Motherboard: ASUS P5Q Pro Turbo
Memory: CORSAIR 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
AMD ($419):
Processor: AMD Phenom II X4 965 Black Edition Deneb 3.4GHz
Motherboard: GIGABYTE GA-790XT-USB3
Old 03-15-2010, 04:42 PM
Dism Dism is offline
Yes. More RAM. :)
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 03-15-2010, 05:49 PM
Originally Posted by Dism View Post
Yes. More RAM. :)
Cool. I'm leaving slots open in the future so I can upgrade. But between the AMD and Intel, any suggestions or reasons why one is the better choice?
Old 03-15-2010, 06:21 PM
The Intel build needs DDR2 not DDR3
Leaving room for expansion is good but you might want to go with 2 x 2GB sticks so you can expand to 8 down the road.
Newegg is listing some P45 boards as open box as low as 66.00. I've had pretty good luck with open box products from them. Unless you are planning on four monitors you may not need the Pro version of the board. Long time DUC'er MATTP has been running ASUS P5Q SE2 and a Q9450 that I traded him for some time now. The P5Q SE2 and the P5Q SE Plus seem to pretty be the same board.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
the box doesn't matter? mcconnellsteve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-25-2006 06:01 PM
Clipping no matter what amorena1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-19-2005 10:41 PM
Won't record PT 4.0.1, what's the matter? cranialcompany Digidesign Hardware & Software 2 11-19-2005 07:54 PM
DOES IT MATTER? jon one 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-13-2003 08:26 PM
From OS 9 to 9.2 does it really matter? Craig Golding 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 12-13-2002 05:42 AM
