Old 05-10-2022, 11:33 AM
PhilSMusic PhilSMusic is offline
Default Sustain Glitch
Hi!
I'm finding that if I end a recording, or reduce a clip size so that it ends when the sustain pedal is down/on, it remains down when I try to record more on that part, even if I use the sustain pedal.
i.e. I decide to change a piano part, so I delete the end of a clip, and when I start recording the pedal is down and wont go up.
Any thoughts - it's a minor annoyance, but hey, they all count!
Cheers folks,
Phil
Old 05-18-2022, 01:59 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Sustain Glitch
Hi, There's a setting in Preferences on the MIDI tab called MIDI Merge Release Mode that you can change to Latch or Latch Until Next Event that should allow you to turn off the sustain with the pedal when you punch in. Hope that helps!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 05-19-2022, 05:21 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Sustain pedal data is like note data. You need pedal down and pedal up or you will be in limbo land.
Punching in with MIDI piano has been a pain since time immortal for this reason. I used to ask the player to arrive playing at the punch point to try to catch the pedal up command but it wasn't perfect.
If you show sustain data in the controller lane you will soon see if there are going to be issues when editing or where a good place to punch in is.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
11Rack will not sustain Bojacka Eleven Rack 4 01-13-2015 08:41 AM
Grouping Glitch? Brain Glitch? americanslidol Pro Tools 11 10 12-05-2014 12:02 PM
Sustain issue mowgli789 Windows 14 07-19-2012 06:25 PM
sustain?? rishabh Virtual Instruments 3 05-23-2007 07:45 PM
Sustain Pedal stut5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-04-2003 11:45 AM
