Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 11-02-2021, 02:45 PM
ScottyD ScottyD is offline
Default Confused by DB25 pinout of MTRX Digital IO
With the HD IO the DB25 carried 8 channels of IO. 2 channels per wire. Hot, Cold, GND.
With the MTRX internal DB25 for digital audio, even though the MTRX manual states the connection follows the Tascam standard it seems it doesn't. It looks like there is only 1 channel per wire. The 8 channels of IO are split into two connections. Is this really the case and if so, why?
I still haven't dug into the pigtail of a Digital expansion card, so I'm not sure what that looks like.
I'm trying to go into a BALUN that has phoenix connections and then converts 110 to 75 via BNC connection to a jackfield. The way it's laid out now I might have to rethink how I wire things up.
Thx in advance,
Scotty D
Old 11-02-2021, 03:11 PM
LukeHoward LukeHoward is offline
Default Re: Confused by DB25 pinout of MTRX Digital IO
The manual is misleading, "channel" refers to a stereo AES/EBU channel. There are 16 real channels of I/O on the chassis, split across two DB25s.
https://lukehoward.com/
Old 11-02-2021, 03:12 PM
JFreak's Avatar
JFreak JFreak is offline
Go google some documents about "single-wire" and "double-wire" AES, that should clear your confusion.
Janne
Old 11-02-2021, 03:15 PM
I don't think this is relevant, I don't believe the MTRX supports double-wire AES. It's just the confusing terminology in the manual.
Old 11-02-2021, 04:45 PM
JFreak's Avatar
I wouldn't know, don't have Carbon.
But to oversimplify things dual-wire AES is like SMUX to ADAT. With that said, if you are using single-wire (normal) AES things are simple: one shielded twisted pair cable (110ohm XLR "mic" cable) carries two channels.
Janne
Old 11-02-2021, 04:50 PM
Sure, but the question was about the MTRX, not the MTRX Studio or Carbon. :)
Old 11-02-2021, 04:58 PM
DetroitT's Avatar
DetroitT DetroitT is offline
I read it as 4 Stereo in AES digital and 4 Stereo Out AES digital (Per DB25), (16 Ch total).
Old 11-02-2021, 05:06 PM
Ah yes, I guess “channel” in the manual is intended to refer to a bidirectional mono channel then :)
Old 11-02-2021, 05:09 PM
JFreak's Avatar
Yes that is how normal AES works. One DB25 connector = four XLR's both ways = 8 channels in 8 channels out.
Janne
Old 11-03-2021, 09:10 AM
It definitely is misleading when you compare to the pinout of the HD I/O and how it labels channels. And I don't think the manual for the MTRX mentions stereo pairs either. So there in lies the confusion.
Where does it say stereo pairs. My guess is it's assumed you know already.
Yup that's what I had in my head, just wasn't sure if they were doing someting in a non-standard way.
Thx for the clarification guys.
Mtrx Studio DB25 Avid Cable for analog input cerisaie Pro Tools | MTRX & MTRX Studio 11 11-16-2020 02:21 PM
How to go from Apple TV digital out to MTRX? SomeOtherGuy Pro Tools | MTRX & MTRX Studio 55 02-08-2020 02:52 PM
FS: Avid DigiSnake 12 ft. DB25 to DB25 Cable (9940-29651-00) TVPostSound Buy & Sell 0 03-27-2017 12:14 PM
DB25 Male to DB25 Female Ext. Cable Barry Johns Pro Tools HDX & HD Native Systems (Mac) 11 06-12-2016 11:30 AM
db25 PC pinout GrantFM ProControl, Control|24, Command|8 3 10-09-2009 11:24 PM
