#241
Re: -9171 and -9172 errors with Pro Tools HD 10.3 on HDX
It has to be HDX. Firmware, Graphic related?...too may times I think i've narrowed it and eliminated it, it's back in a different scenario. (VI or no Vi's I get these.)
My 10.3.x TDM/magma systems have never had these errors. They seem to ebb and tide here.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
#242
Thanks Marvin. "glad" to be here. It's been 512 or 1024 since the HDX install. Never below. Issues started and persisted at those buffer sizes.
#243
what exactly does this mean? (just curious why you asked) thanks |
#244
I will switch to 1024 and 6 processors - and see if i get any errors thanks |
#245
i want to know if our hdx cards are on the same firmware!
Selling: |
#246
From Console right at 9171 error:
12/10/12 10:09:52.020 PM sandboxd[2085]: ([2063]) mdworker(2063) deny file-read-data /Library/Application Support/VSL/libveproshared.1.0.0.dylib (import fstype:hfs fsflag:4A09000 flags:200000056 diag:0 uti:com.apple.quicktime-movie plugin:/Library/Spotlight/CoreMedia.mdimporter - find suspect file using: sudo mdutil -t 2438167) 12/10/12 10:09:52.041 PM sandboxd[2085]: ([2063]) mdworker(2063) deny file-read-data /Library/Application Support/VSL/libveproshared.1.0.0.dylib (import fstype:hfs fsflag:4A09000 flags:200000056 diag:0 uti:com.apple.quicktime-movie plugin:/Library/Spotlight/CoreMedia.mdimporter - find suspect file using: sudo mdutil -t 2438167) 12/10/12 10:30:03.426 PM WebProcess[2181]: Can't open input server /Library/InputManagers/QuicKeysIM 12/10/12 10:30:03.636 PM Safari[2180]: Can't open input server /Library/InputManagers/QuicKeysIM 12/10/12 10:30:11.807 PM PluginProcess[2188]: Can't open input server /Library/InputManagers/QuicKeysIM 12/10/12 10:31:15.000 PM kernel[0]: Sandbox: sandboxd(2195) deny mach-lookup com.apple.coresymbolicationd 12/10/12 10:31:16.362 PM sandboxd[2195]: ([2177]) mdworker(2177) deny file-read-data /Library/Application Support/East West/Frameworks/QtCore.framework/Versions/4/QtCore (import fstype:hfs fsflag:4A09000 flags:200000056 diag:0 utiublic.mpeg-4 plugin:/Library/Spotlight/CoreMedia.mdimporter - find suspect file using: sudo mdutil -t 2352903) 12/10/12 10:31:16.410 PM sandboxd[2195]: ([2177]) mdworker(2177) deny file-read-data /Library/Application Support/VSL/libveproshared.1.0.0.dylib (import fstype:hfs fsflag:4A09000 flags:200000056 diag:0 utiublic.mpeg-4 plugin:/Library/Spotlight/CoreMedia.mdimporter - find suspect file using: sudo mdutil -t 2352903) 12/10/12 10:31:16.422 PM sandboxd[2195]: ([2177]) mdworker(2177) deny file-read-data /Library/Application Support/VSL/libveproshared.1.0.0.dylib (import fstype:hfs fsflag:4A09000 flags:200000056 diag:0 utiublic.mpeg-4 plugin:/Library/Spotlight/CoreMedia.mdimporter - find suspect file using: sudo mdutil -t 2352903) 12/10/12 10:31:16.434 PM sandboxd[2195]: ([2177]) mdworker(2177) deny file-read-data /Library/Application Support/VSL/libveproshared.1.0.0.dylib (import fstype:hfs fsflag:4A09000 flags:200000056 diag:0 utiublic.mpeg-4 plugin:/Library/Spotlight/CoreMedia.mdimporter - find suspect file using: sudo mdutil -t 2352903) 12/10/12 10:31:16.441 PM sandboxd[2195]: ([2177]) mdworker(2177) deny file-read-data /Library/Application Support/VSL/libveproshared.1.0.0.dylib (import fstype:hfs fsflag:4A09000 flags:200000056 diag:0 utiublic.mpeg-4 plugin:/Library/Spotlight/CoreMedia.mdimporter - find suspect file using: sudo mdutil -t 2352903) 12/10/12 10:31:21.112 PM Console[2198]: Can't open input server /Library/InputManagers/QuicKeysIM ---- Does this mean anything? Should we be posting this kind of info? (apparently there is some characters in there that cause a smiley face.....don't know how to change that.)
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
#247
Hi Ron,
I know they need the .dlog files that are in ~>Library>Logs>AvidLogFiles Maybe Tech Supprt can chime in and give you an email to send them to. Cheers!
My System is: Mac Pro 3.2GHz 6 Core 32GB RAM 1- HDX 1 - Apogee Symphony Mk2 8x8 1 - HD 16x16 Interface MOTU MTP/AV ------------------------------ Second System Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2 32GB RAM 1 - HDX 1 - Avid Thunderbolt 3 Expansion Chassis 1 - HD 8X8 Interface MARVINBASS Digital Audio, LLC Ex PT Beta Tester Woodland Hills, CA. |
#248
buffer at 1024
processors at 6 no errors today. |
#249
How do you read Library>Logs>AvidLogFiles?
In Console it's just ???fonts (.dlog)
#250
I've been doing pretty some testing, using this as a guide.
http://avid.force.com/pkb/articles/e...ve-errors-9071 I found these unlisted factors causing -9171 and -9172 errors: - idle, non-sleepable, Firewire 800s drive make 'write' sound, error occurs - Using Structure - Using VI ------------- Because this appears to be a buffer issue, I'll report these additional behaviors. 1 - In an effort to stop -9171 and -9172 errors in an audio only cached 120 voice film mix, I raised the buffer from 512 to 1024. This resulted in my dialogue being out of sync, and what sounded like a 2 sample discrepancy in bussed tracks that was causing phase cancelation. I saved the session with the new buffer setting (PT retains session buffer settings), and restarted. Problem went away. 2 - Despite the above session being cached (14gig) and at max H/W Buffer, playback start causes intermittent -9171 and -9172 errors, accompanied by a split second of garbled phase-y audio. 3 - When changing the buffer settings in a MIDI and audio session, Avid VI's exhibited a 100 sample offset, while VEP5 remained perfectly in time. (cause is RTAS non-adaptive delay comp?) Saving as the new buffer and restart did not fix it. -------- Note: The film session had basically no CPU load at all, HDX was nowhere near overtaxed, and the MIDI/Audio sessions reported zero CPU spikes. Hope this helps in the debug process. |
Pro Tools 10.3 9171 and 9172 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 20 | 07-14-2013 03:11 PM |
-9171 and -9172 errors constant...Sandra attached | wrachilla | Windows | 12 | 05-09-2013 09:19 AM |
UAD triggering 9171, 9172 errors? | xq3js | macOS | 7 | 03-22-2013 11:47 PM |
Dae errors -9171 after installing 10.3.3 | TCM | Pro Tools HDX & HD Native Systems (Win) | 3 | 02-06-2013 10:18 AM |
10.3.3 Major Fail....9171, 9172 and 9129 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 3 | 12-21-2012 07:21 PM |
