I can't change the input tab
Hi.
I've reset the I/Oa to default, but can't get the input tabs to change to 'input" or "bus" I am running my projects with Focusrite and an external drive. It just seems to be on some projects and not all. I have recently started using an M-Audio Oxygen, but don't think this should impact my audio. Any help welcome. |
Re: I can't change the input tab
Playback Engine ?
^^ exactly.
Most likely cause on a Mac (like you are using) is Pro Tools has selected Built-In Output or similar as your playback engine and it does not have any inputs for you to choose. If so it's doing exactly what is expected. |
Can't change Input on Audio | peterbrookes | Pro Tools 2018 | 2 | 06-02-2019 04:15 PM |
Change the input and keep the output? | CalebT | Pro Tools | Intro Discussion | 6 | 10-24-2018 12:21 AM |
Can't change input assignments in PT 11.3.0 HD | SteveGarman | Pro Tools 11 | 5 | 07-14-2015 02:28 PM |
Change default input? | Tom Case | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-06-2009 07:43 PM |
no input signal when I change from +4 to -10 | gw sound | Pro Tools TDM Systems (Mac) | 2 | 08-01-2005 08:18 PM |
