Cubase 8 and Eucon?
Have upgraded to Cubase 8 and Eucon does not have much functionality with the upgrade. Transport controls don't work etc. - although it does register in Eucon as using Cubase8 setup.
Functionality was fine in Cubase 7.5. Any ideas as to how I could get the same in Cubase 8? Can't even find a Cubase8.xml file in the library folder! Thanks Douglas
Interface Studio Mac 1 System CubasePro 11, Pro Tools 2021.7 MacPro 3.5Ghz Six Core Intel Xeon, 64Gb ram, OSX 10.15.17 Avid Duet, 3 x Avid S1, ProTools Dock, Ableton 10, Reason was 12, NI Komplete 12, NI Komplete Kontrol S61 and S88 Mk2 Mac 2 System ProTools 2019 MacPro 3.5Ghz Six Core Intel Xeon, 16Gb ram, OSX 10.13.3 Digi 003 rack Slate Raven MTi2, Avid MC Transport |
Re: Cubase 8 and Eucon?
I think I've found an easy fix for this.
The default Cubase Eucon settings seem to be saved in Library/Application Support/Euphonix/DYN_APPSETS The file I had saved there was Cubase7.xml - I renamed it Cubase8.xml and all my previous soft key maps etc loaded in when I ran Cubase 8. Hope that helps someone.
Autobank has stopped working for me in C8. Tried to look for xml file as above (there's actually 5 of them in W7) but there were C8 versions already there. Reverting to C7.5.2 for now, which is fine (as are all versions of PT).
Win7 64bit, i7 4930, 64gb ram, eucon 3.2.1.
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM |
Just doing a canvass for anyone with Cubase Pro8 and EuControl 3.2.1 to do a check on autobanking. I hear it works on Win 8.1, but run out of ideas to fix this.
Did you try trashing the Cubase Preferences folder? Were you also careful not to let Cubase Pro 8 steal settings from previous Cubase versions? You should really do this every time you upgrade! I've had previous versions of Cubase behave very strangely by not following this procedure! Al
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit) Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3 |
EDIT - in fact, it was much more basic than that - forgot that project and mix windows need to be synced! Doh.
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM Last edited by noiseboyuk; 12-10-2014 at 03:59 AM. |
Adding to this: I also had to rename the default settings from 7 to 8, but in order to make it work properly I also had to delete the Cubase8.xml located at Library/Application Support/Euphonix/UserSets/MC2User and restart Eucon.
PT 12.7.1 @ OSX 10.12.1 RME Babyface Pro - MC Control V1 |
Cubase Crashes from EUCON | aptmusic9 | Artist Series | 0 | 06-05-2014 08:40 PM |
Violent Eucon Crash in Cubase 7.5 | aptmusic9 | Artist Series | 1 | 03-17-2014 08:41 PM |
I need some serious help... Eucon is breaking Cubase | 73* | Artist Series | 2 | 02-07-2012 01:11 AM |
Eucon don't works with Cubase 6.0.2!!!!! | MiroslavH | Artist Series | 7 | 05-30-2011 05:43 PM |
Cubase 5.5.2 And EuCon 2.5.6 | dvrooman | Artist Series | 2 | 11-10-2010 12:20 PM |
