Old 09-19-2003, 02:52 AM
mixerboy mixerboy is offline
Default Change sample rate???
Is there a way to change sample rate in pro tools? I have some audio that is playing back at the wrong speed.
Old 09-19-2003, 05:05 AM
fredsparky fredsparky is offline
Default Re: Change sample rate???
Yes. You can change the sample rate when you first create a new session. You can also change an existing session sample rate by selecting "save in"- not "save as".
Good luck.
FS
July
MP3's
Old 09-19-2003, 10:28 AM
You can use my Header Investigator program to change the sample rate in the WAV file header to match the sample rate of the audio data.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 09-19-2003, 01:31 PM
JMS40 JMS40 is offline
You should be on the payroll, Rail.
Thanks for all you do around here. You are a real asset.
Jonmark
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
Can't change sample rate Gabriel_S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-20-2012 11:43 AM
Can't Change Sample Rate jasonschwartz Pro Tools M-Powered (Win) 1 01-11-2007 11:13 PM
how to change sample rate?? remains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-28-2002 04:38 PM
Change Sample Rate in HD? Steven Sena Tips & Tricks 2 08-10-2002 06:33 PM
