Old 10-16-2012, 10:56 PM
realizment realizment is offline
Default Understanding automation / faders control?
Hi guys,
im starting back at PT now its been a few years. Im wondering if i set some volume automation on a track in 1 or 2 places, do i now need to use the automation to set my fader level in general.
For example.. if i have done a balance, then do a little automation, then client asks me to bring the x y and z track up a little, i cant do it unless i do it in automation lane? I cant just pull fader up a little as automation just send it back down?
Thank you
Old 10-16-2012, 11:47 PM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
Default
Use trim mode. If you only want to offset levels up/down for the whole duration, you can easily do it in read+trim.
When all is good you can coalesce (ie: permanently burn) the trim/auto move(s).
Combine Trim with Touch or Touch/Latch if you want to drop in to do some actual adjustments to your written auto moves at specific spots.
As soon as I have my initial balance I put everything in touch+trim and build my mix as I go.
If on hd/cptk, check out the manual to see how you can use the powerful rehearsal features. for ex, to loop sections and adjust everything (plug-ins included) to perfection before comitting the auto. VCAs are also very useful and powerful mixing tools to learn to use.
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
Old 10-17-2012, 12:11 AM
phatbeatstudio phatbeatstudio is offline
Default Re: Understanding automation / faders control?
Originally Posted by realizment View Post
Hi guys,
Thank you
Once you have automation that is how it works
When I started with PT 2 years ago I watched a tutorial where he put the trim plug on every track in the first plug box.
I dont put trim on every track now but I always leave the first box open just in case.
If you dont want to mess with the pencil tool to redraw automation
use to trimmer tool on the fist selection and you can move up or down the entire area of volume between the break points . Keep in mind it does work for complicated automation just between one break point to the next
I like to put break points where I want them, find out where I want the volume and use that trim tool to move the entire section up or down . FASTER THAN THE PENCIL at least it is for me
There is a better way, as said in the above reply but this is convenient and works just as well and fast . This is how I do it unless i need the extra plug in box .
control plugin parameters and sends with faders on MC Control jacko Artist Series 1 01-03-2011 03:12 AM
Understanding the Mute control on an effect send DonaldM Tips & Tricks 9 10-19-2008 05:05 PM
Korg microKontrol - Assign Faders/Automation Control Over PT sleazedc MIDI 9 09-27-2008 06:51 PM
Understanding gain control... richiebee ICON & C|24 0 09-18-2007 10:34 AM
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... domsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2004 07:06 PM
