Sound Control Panel & Digidesign CP problems...
Ok
when i select "digidesign" from the sound control panel (CP) sometimes i hear the beep out of the 888 and sometimes not... Sometimes other Sound Manager apps can utilize the 888 and sometimes no.. and USUALLY once the Sound control panel is selected to Digi output, when i try to load PT (with no other apps running) its says hardware in use by other app... Sometimes it works just fine also Is it just buggy as hell or is there something im doing wrong? Mix plus, 9.0.4, 5.0.1 (also with 5.1 on my other rig) any help would be great. thanks
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
Re: Sound Control Panel & Digidesign CP problems...
I too am confused by the Digi Control Panel. It has a button that let's you select the hardware Setup dialog, but seems to have no effect on routing non Protools stuff like Quicktime to the Digi Hardware. I use the Sound Control Panel and select Input as Built In and output as Digidesign. Is this correct or am I missing something?
------------------ [email protected] http://www.catasonic.com |
I´ve been trying to solve this for a long time now.
I think its when I use the internet on my mac that remote access doesnt release the hardware to PT after. Havent been able to find a solution... Ben
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Digidesign- Mac Sound manger control panel | JKROUGHS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-26-2002 06:19 PM |
More than one Digidesign output listed in Sound Control Panel | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-01-2002 02:23 PM |
Computer Sounds Out Via Digidesign in Sound Control Panel | fmckinnon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-22-2002 08:25 PM |
Digidesign sound control panel slows mac down | voltech | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-09-2002 08:11 AM |
Digidesign Sound Control Panel | Kenshiro | Pro Tools TDM Systems (Mac) | 4 | 07-07-2000 01:41 PM |
