Old 08-07-2017, 09:06 PM
zhaojian zhaojian is offline
Default (-9105) Error Occurred When Switching Sessions
1. I am working a normal session. And I need to open another session. For example Reel01 and Reel02.
2. So I close my current session. After it totally closed. I double click the other session file which in another session folder. The dialogue windows flash a few seconds and then an error occurs indicating "Could not complete your request because (-9105) while translating Tracks".
3. When I click OK. The dialogue window disappear. If I double click again. The session may open successfully. But sometimes pro tools will quit unexpectedly.
4. As someone said before. I try to right-click on the second session while the Pro Tools is in the front. Choose open with pro tools. It works.
5. I also have seen many of users said that Altiverb may cause this issue because -9105 is a plugin activation error. But when I Remove All Altiverb(7.2.9) Plugins (not make inactive) in these two sessions. This error appeared again when I do the switchover.
Hope This Annoyed Issue Can Be Solved. I Will Keep On Trying Other Ways To Find The Problem.
If Anyone has tried any ways, I really hope u can discuss below.
Pro Tools HD 11.3.2
HD MADI & Sync HD
HD Driver 11.3.2
OS X Yosemite 10.10.5
Old 08-07-2017, 10:42 PM
J.D. Andrew J.D. Andrew is offline
Default Re: (-9105) Error Occurred When Switching Sessions
You aren't by chance using Console 1 are you? I've been having a problem with it being the culprit of a ton of -9105 errors.
jd
Old 08-08-2017, 02:36 PM
Will Russell's Avatar
Will Russell Will Russell is offline
Altiverb also threw these errors on session close when using certain third party IRs
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 08-08-2017, 08:57 PM
Hi, Andrew! Thank you for your reply!
I don't use Console 1 and I also have read your post about this issue. Maybe Console 1 has the same crash-point with Altiverb.
Old 08-08-2017, 09:31 PM
Hi, Will.
You are right.
I have found that Once the error occured, No matter Altiverbs exist or not in my session. The 9105 error do will come up. Only if I restart the Pro Tools App, the error doesn't show any more while I switching sessions with no Altiverbs.
One more thing I want to say. The Altiverb in my session was imported from another session. So When I delete the Altiverb and REinsert a new Altiverb and do some automation edit on altiverb track. The error doesn't show any more.
Error -9105 while opening sessions dwaynedelario Pro Tools HDX & HD Native Systems (Mac) 10 08-21-2020 12:01 AM
Error -9105 when opening sessions in PT12 Rowan Watson Pro Tools 12 3 05-11-2017 12:38 PM
Plug-in can't be activated - DAE error #-9105?? dingobiatch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-04-2007 02:08 PM
DAE error #9105 tritonkorg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-07-2005 08:48 AM
6.9.2 Crashes When Switching Sessions ronstephens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-18-2005 10:14 AM
