Waves Vocal Rider - Setup
This might be a stupid question, but I am a bit confused.
When I want the Vocal Rider to be "controlled" by the music how do I set that up. I assign a bus from each track and select it in the side chain input - somehow it's not possible to select a stereo sidechain - is that right? I can only select a mono bus. It seems as if the Vocal Rider only reacts to it's own signal and not the sidechain signal - what could I do wrong? Thanks for any suggestions! |
Re: Waves Vocal Rider - Setup
I think sidechains react the same way as the mixer. So if you are inserting the plugin on a mono track, just as you would not be able to select a stereo bus as input, you can't select it as a sidechain input, either.
Sending all your sources (both mono and stereo) via mono to create a sidechain bus would obviously create an unbalanced mix, but the overall changes in RMS should still dictate the same changes in dynamics in your mix.... all you have to do is adjust the music sensitivity and target thresholds to taste. Is the LED next to the "Music" knob lighting up after you set up your sidechain? |
I am inserting it on a stereo track and I'm only able to select mono-busses. Yes the led lights up - it's green - would it be possible to send a screenshot of your setting.
Do I have to use send-busses or do I have to buss all channels into the sidechain? |
waves vocal rider is it any good | Raoul23 | Pro Tools 9 | 15 | 03-28-2011 02:34 AM |
Waves Vocal Rider - TDM or RTAS | GS-DK | Pro Tools TDM Systems (Mac) | 19 | 11-03-2010 11:08 PM |
Waves Vocal Rider bug. | usastra | Pro Tools TDM Systems (Mac) | 2 | 01-05-2010 04:00 PM |
Waves vocal rider | crizdee | Pro Tools TDM Systems (Mac) | 8 | 11-03-2009 10:42 AM |
Upcoming Waves Vocal Rider | danander11 | Tips & Tricks | 9 | 10-17-2009 04:17 PM |
