I lose command focus when I switch spaces
Hey,
So, I have a good workflow between my music apps (Pro Tools, Reason, Kontakt) by using spaces. I have PT is space 1, Reason in space 2, etc. Often, when I switch back to space 1 to work in PT, I lose command focus. That is to say, my single stroke key commands stop working temporarily. Clicking on the [az] in the top right corner of the edit window doesn't do anything. To fix, I quickly flip back and forth from another space, then click in the PT edit window. That restores the command focus. Any idea why this happens? Thanks Adam |
Re: I lose command focus when I switch spaces
I brought this up in another thread last week sometime. I said I was losing command focus as well, when I was using expsose to swith between the mix and edit windows.
Turns out though that you really don't lose it. I noticed that when the edit window is brought to the forefront it is really not selected yet. It's there but lightly grayed out around the edges, check the "x,-,+" in the upper left hand corner. They will probably be grayed out. Then look at your command focus, it will probably look turned off. Then click in the middle of the edit window. Ta-da, everything's fine. Hope this helps.
iMac 20" 2.4Ghz Intel Core 2 Duo, 4GB 667 Mhz DDR2 SDRAM, Guitar Rig Session I/O, M-Audio Axiom25, Pro Tools 10.1.3, Mackie Mr8mkII Monitors |
I use option O (as in open project browser) twice to bring mine back...weird bug and I've been too busy to bitch about it. Thanks to you for calling this one out. I can't figure out how it gets turned off just how to get it back this way.
My day job: Wilson Dyer MPSE Sound Supervisor: NCIS Los Angeles, CBS Television |
command focus | Macsearcher | macOS | 2 | 02-26-2014 02:21 PM |
command focus | StainedClass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-09-2012 10:44 AM |
MC Control and MC Mix lose focus | paranerd | Artist Series | 7 | 03-29-2011 03:16 AM |
Command Focus bug? | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-27-2009 05:31 PM |
Command Keyboard Focus mode ' E ' command bug ? | vudoo | Pro Tools TDM Systems (Win) | 2 | 09-10-2009 05:49 AM |
