from what I understand SVP will not work with digi001. keep trying and let us know how you get it to work cause I love that program although I only have v 4.01 and use it with my am3, never tried it with my digi001.
Is anyone here is sucessfully using a Digi 001 w/ SVP 4.5.1, without any
problems? The major problem I am having is audio playback will just randomly stop. I'm just talking about a single stereo interleaved track of audio...when in Acadia. Playback in Sound Manager is ok. Tried all the optimized Acadias', same problem though. Is the problem the ASIO Direct IO driver choking? I've also tried the ASIO DigiDesign Direct IO ( from the Steinberg site which Digidesign suggests )...but I'm still having the same problem. No other Audio programs such as ProTools LE 5.1, Masterlist CD, Jam, Toast, imovie etc.. have any problems with audio playback, just StudioVision. If anyone here has the 001 working flawlessly with SVP 4.5.1, what exact extensions, drivers, setup are you using? I had an AMIII card on this G4 for about a year...never had a single problem. ----------------------------- G4 MP533 - OS 9.2.2 896 mb ram, VM is off, disk cache set to 512k SVP 4.5.1, Acadia 1.0.1 ( tried 1.0.3 and all the optimized versions with SVP 4.2.2, made no difference ) DAE / DSI 5.1.1 ( tried 5.1 versions, made no difference) Digi Control Panel & extensions 5.1.1 ( tried 5.1 versions, made no difference ) [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] |
I remember being successful using Vision DSP software (which also uses the Acadia audio engine) with Digi001 hardware via Direct I/O...no ASIO driver was needed. However, this was with DSI 5.0 (when the Direct I/O instuction set was included in the extension).
-If you don't have a Direct I/O option with your current versions of DSI and Direct I/O extensions, try reverting to DSI 5.0 and see how things go. Brent |
Why run with Acadia?
You need SVP 4.2.2 IMO. Turn off the 001 MIDI instrument. Then set Vision to the 001 hardware. You can turn on the MIDI instrument (001's) after it instantiates. Turn it off before you shut down. There may be problems with 9.2.2 vaguely remembering something... 4.5.1 is also kind've buggy. Check out: http://fm-music.com/v/setup/setup.html (once you edit w/ 4.5 and save. 4.2.2 cannot open them again)
"The original nipper" Throw me a bone (Telefunken DI is ok too) |
SVP 4.5 works exellent on my beige G3 computer except when ADAT is assigned.... the known beige issue.
When SPdif assigned everything works fine. over 48 tracks are possible...... minimum extension list, no ATI extensions, no digi midi extension...... Once i get an S/Pdif connection for my powerbook G4 .... i`ll be running protools and SVP at the same time ... Oh yea in the soundcontrolpanel do not use digidesign outputs.... keep using the mac built in outputs.... sometimes a comflict may occur when starting protools.... from what i`ve heard from people ... i never experienced it. |
Anyone still using Opcode Vision or Studio Vision? | Boom Chic | MIDI | 1 | 05-22-2002 12:35 AM |
001 and Studio Vision Pro? | MC1000000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 05-17-2001 06:01 AM |
Anyone using HUI with Studio Vision? | Boom Chic | Pro Tools TDM Systems (Mac) | 1 | 12-20-2000 12:26 AM |
DIGI & Studio Vision Pro 4.5.1 sync problem | soren | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-10-2000 12:59 AM |
Z STUDIO VISION 4.0 | EARDELI | Post - Surround - Video | 1 | 06-25-1998 04:17 PM |
