7.4cs2 issues
Having spent the day running cs2, I have found the following:
- While I have never been a fan of the colored mixer, I did try it out today, and now I cannot get the "grey" mixer back! I can go from full color saturation, to barely any color at all, but cannot go back all the way. Now I'm REALLY not a fan of the colored mixer. - Menus often stay highlighted. After making a choice in a menu, the menu disappears (as it should), but the menu heading stays highlighted. I've never seen that one before, but I sure saw it a lot tonight. I hope when I wake up tomorrow, these issues will be gone. |
Re: 7.4cs2 issues
@wildhoneymusic http://kidzbop.com/music/ https://concord.com/publishing-roster/gary-philips/ |
Re: 7.4cs2 issues
Now that I upgraded to 7.4cs2, my waves SSL 4000 channel strip distorts on some sessions. It's a non musical white noise type of thing. Not good!
-Tom
http://SpeakRecords.COM |
Re: 7.4cs2 issues
Another day of work, still more problems, related to the above. I just lost keyboard control yet again. But this time, I could not quit PT by using the mouse either. All this after I had already trashed prefs, databases, etc.
I had none of these problems with cs1. |
Re: 7.4cs2 issues
BTW, the phantom colored mixer that I could not banish no matter what last night when gone this morning.
Re: 7.4cs2 issues
The keyboard lock-out problem goes away with a PT reboot. I had none of these problems with cs1. |
Re: 7.4cs2 issues
the scrubber used with the time expension fonction does not strech the audio file at the right place in the grid when reducing the file's length. (since 7.4)
When selecting an object in free mode at maximum zoom. You cannot select the object exact's lenght without having a selection with plus a sample or minus a sample.
My soundcloud page Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8 |
Re: 7.4cs2 issues
Re: 7.4cs2 issues
Please Digidesign |
Re: 7.4cs2 issues
Hey there
Apart from the Color mixer issue (which i dont use), all the others i have experienced too. Mark - the highlighted menus staying on has been around since 7.2, but now in 7.4 it seems that like Wildhoney says, sometimes you cannot even use the menus with the mouse. All this has been mentioned a million times before on the forum - search for "keyboard" Tom - that white noise from you SSL plugs has again been around since at least 7.2. You'll find its isolated to the Dynamics section, so if you're not using it, bypass and the sound will go, or alternatively, move the Ratio knob down and then back up past 3:1 and it'll go away.... till you reload the session. I've emailed sessions to Waves but they we're no help with this. Digi, this is by far one of the most common problems now, since 7.2 Yet we're constantly told it can't be recreated. If a hundred users can make it happen surely your testers can. Please resolve this time consuming major bug relating to the keyboard dropping out and the menu's being frozen from use. fman |
Did 8.0.4cs2 fix the response issues with the 003 | converted | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-07-2011 12:14 AM |
8.0.4cs2 anyone have these issues? | albee1952 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-30-2010 10:16 PM |
Has 8.0.4cs2 fixed the response issues with the 003 | converted | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-29-2010 09:36 PM |
RND Inspector and PT 7.4cs2 | peter kuchar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-09-2008 08:53 PM |
7.4cs2 - Is it safe? | subwoof | Pro Tools TDM Systems (Mac) | 13 | 01-11-2008 11:10 AM |
