Old 06-19-2007, 08:11 AM
digimutt digimutt is offline
Default Shared Library Error - on OS 10.4.9
Mac G4, 733 mhz PPC, 1.12 GM SDRAM,
Tiger 10.4.9, PT LE 6.9.2, upgraded from PT LE 6.9
MBox
I reinstalled OS X 10.4.9 on my G4 recently.I did not have any problems with pro tools before, but after I reinstalled the OS and protools, I got this error when I tried to start PT:
The application "Pro Tools LE 6.9.2" could not be launched because of a shared library error: "4<Pro Tools PPC dbg><Pro Tools PPC dbg><DAE><FreeFic>"
I was not able to fix the problem except by reinstalling the OS. After I did that, it worked fine. But as soon as I install another program that uses the same copy protection software, I get the error I mentioned above. I have followed the instructions on the Answerbase for erasing certain files and reinstalling PT, but it doesn't fix the problem. The only thing that has worked is reinstalling the OS. Why is this happening? What should I do?
Old 06-19-2007, 09:11 AM
DigiTechSupt's Avatar
Default Re: Shared Library Error - on OS 10.4.9
You should do a clean uninstall of Pro Tools - run the Pro Tools installer for 6.9.2 and, when you get to the 'Custom Install' page, click on the word Custom Install and select Uninstall from the drop-down menu. When prompted, do a 'Clean' uninstall, then restart and reinstall.
Avid Audio Tech Support
Support FAQ
Old 06-19-2007, 09:24 AM
This is exactly what I did and have done many times, but I get the same error. I have tried to uninstall and reinstall the PACE software, I have deleted the database files, I have deleted all the related files from home/library/preferences. I have repaired permissions, nothing seems to help except reinstalling the OS, but then once I install any other software with the PACE protection, I get the error again. I actually wrote to someone before about it, but the thread got too old. The Subject was "Shared Library Error PT LE 6.9.2 on Tiger"
Old 06-19-2007, 10:43 AM
I think you should give an EXACT step by step of what you're doing - obviously there's something in that process that's going awry and knowing what you're doing will help narrow down where the problem is occurring.
Support FAQ
Old 06-19-2007, 11:22 AM
Okay,
1. double-clicked on "ptle692_26140.dmg"
2. clicked the Install Pro Tools Icon
3. Chose uninstall
4. choose Clean Uninstall
5. does it, then I get message "Uninstall was successful, but some files/folders could not be deleted because they are shared by other applications.
6. Clicke on PT CD icon
7. click uninstall icon
8. click uninstall pT
9. choose clean uninstall
10. get the same message about not all files being deleted.
11. went to home/Library/Preferences and deleted com.digidesign.COreAudioManager.plist
12. restarted computer
13. reinstalled OS X combo update that is recommended on your site.
14. restarted
15. Click on PT CD icon
16. Install PT and Digidesign Core Audio.
17. restart
18. install from "ptle692_26140.dmg" smae way.
19 restart
20. get same message
Old 06-19-2007, 11:25 AM
Did you ever have any other version of Pro Tools installed on this computer?
Support FAQ
Old 06-19-2007, 11:57 AM
Yes, I used to use 6.7.
Old 06-19-2007, 12:13 PM
Ok, this could get a bit tedious.
First, do you have an installer/uninstaller for 6.7? If so, you should do a clean uninstall of ALL versions of Pro Tools that you've ever had installed, restart and reinstall.
If that work - you're good to go.
If not, let me know and I'll collect all the info necessary to help you remove all components manually.
Support FAQ
Old 06-19-2007, 02:04 PM
I ran the a clean uninstall from the 6.7 and 6.0 cds and the same problem occurred. I don't know if there were any downloaded updates I forgot about.
I was not having any problems until I decided to reinstall OS X and reformat the disk. When I put everything back, I put PT on first, and It worked fine. Then, I installed the core audio driver and the problem started. I tried uninstalling and reinstalling, but I could only get PT to work after I reinstalled OS X and reformatted the disk. Another time when I reformatted and had PT working, I installed other software called MAX/MSP, which also has the PACE protection software. Immediately after I installed it, PT got the Shared LIbrary Error. Also There are times when during installing PT, I get this message:
An item in the Startup Items folder ("LIbrary/Startup/Items/PACESupport") does not have the proper security settings.
there are choices: decide later, disable, fix.
It happened when I installed this last time, and this time, I chose FIx. Other times I have chosen the other two.
Old 06-25-2007, 07:33 AM
It didn't work. What do I do now?
Shared Library error ebb2442 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-21-2011 01:27 PM
shared library error st_nick123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-16-2007 09:08 AM
Shared Library error! Love Monkey Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-14-2007 01:55 PM
Shared library error ERIC S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-02-2004 04:23 PM
Shared Library Error? minnie566 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-25-2003 03:48 PM
