Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 04-27-2021, 08:20 PM
starlingmusic starlingmusic is offline
Default MTRX Studio, need more than 16 analog inputs
Hi Everyone,
Quick question:
If I need more than 16 analog inputs (TRS)
what is best/doable?
buy another MTRX studio? and link it to the same HDX card on port 2
or do I need a second HDX card,
In that case how do you link the two HDX cards when they are in a Thunderbolt 3 rackmount.
Using another Thunderbolt 3 cable between the 2 TB3?
Thank you all.
PC: Dell Precision T7920
CPU: Xeon 3104 @ 1.7GHz x2
GPU: NVIDIA Quadro RTX 4000
Ram: 80GB
OS: Windows 11 Workstation,
HW: Pro Tools | HDX TB3 MTRX Studio Bundle.
SW: Pro Tools Ultimate 2023.12.1
Old 04-27-2021, 10:26 PM
Default Re: MTRX Studio, need more than 16 analog inputs
A single HDX card can support up to 64 inputs and outputs so no, you don't need another HDX card (if you did, though, it would need to be in the same computer or chassis as the first card as they are connected directly to each other by a short TDM/SATA cable).
As an alternative to a second MTRX Studio you could use a MTRX with multiple A/D cards but, it may not work out any cheaper though.
https://lukehoward.com/
Old 04-27-2021, 10:54 PM
BScout BScout is offline
A lot of issues with your question.
First off, if you need more analogue inputs, then yes, another interface will be necessary (doesn't have to be MTRX Studio.) BUT.... you could also use the DANTE on the MTRX Studio to expand to more analogue inputs. There are plenty of DANTE to Analogue converters.
As Luke mentioned, each HDX card supports 64 channels. If you were using the full complement of i/o on the MTRX Studio, that would require using all 64. If you aren't, you could only use 32 channels (one port) and attach a second interface for another 32. (However, if you use the DANTE mentioned above, you'd be using both ports again)
As for multiple HDX cards -- depends on the chassis. No, you can't use multiple chassis with HDX cards in each of them. HDX cards have to be all in the same chassis. Sounds like you are using the Avid one that can only hold 1 HDX card. Sonnet and Magma both make chassis that can hold up to 3 cards. When multiple cards are in the same chassis, there's a little ribbon cable that connects the HDX cards together.
Old 04-28-2021, 05:16 AM
uptheoctave uptheoctave is offline
I suggest expanding it with Dante.
Products such as the Focusrite A16R, Ferrofish Pulse DX, Lynx Aurora Dante and others.
You might want to think about going for something fan-less (Aurora and Ferrofish) but it is your call there.
All you need to do is connect the devices to the same ethernet network and route them in Dante controller and they will turn up as Pro Tools IO.
As stated, you have up to 64 channels to play with when using the MTRX Studio, and it will work with a single HDX card.
If you need to expand beyond one HDX card (ie want more than 64 channels of IO) then you need to have the HDX cards housed in the same chassis, as they need to be connected together with a small, supplied cable.
Originally Posted by starlingmusic View Post
Hi Everyone,
Quick question:
Thank you all.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 04-28-2021, 07:56 AM
bewk's Avatar
bewk bewk is offline
There are the optical converters as well. It has 16 channels of ADAT built in so those could be used with an analog front end. Some options out there for 8 channel mic pres that convert directly to ADAT.
• MacPro (4,1 to 5,1) 12 Core 3.46 GHz // 96GB // AJA Kona LHi // OWC FW800, USB 3.0, eSATA
• PT HD|Native 2022.9 on 11.6.8 (OpenCore Patcher 0.4.2 on Crucial SSD)
• PT HD 2021.3 on 10.13.6 // MacBook Pro 17" 2.66 GHz i7 8GB RAM
• Avid Dock,
Artist Series Mix & iPad 7th gen & EuCon 2022.9
• DADman/Eucon monitoring
• BSS (DAN + 100), QSC DCA 1644, JBL 7 Series
• MTRX Studio // 7.1 (7.1.4 pending)
www.quesound.com
Old 04-28-2021, 05:47 PM
This will be the least expensive option :)
Old 04-28-2021, 07:12 PM
JCBigler's Avatar
JCBigler JCBigler is offline
Hi Everyone,
Quick question:
You can get an HD I/O and attach it to the PORT 2 Digilink port with whatever I/O card you need on the MTRX Studio for another 16 channels. Then you attach another HD I/O to the second Digilink port on your HDX card, and hang another HD I/O off the expansion port of that HD I/O for 64 channels into Protools via your HDX card and MTRX Studio.
Or you can use Dante. Or you can use ADAT. ADAT is probably the cheapest way to go. But the HD I/O is the more Pro way to do it. Dante is the Future networking guru way to do it.
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 04-29-2021, 07:44 AM
creativecontrol's Avatar
Here's an interesting option for ADAT expansion:
https://www.cranborne-audio.com/500adat
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 04-29-2021, 08:59 AM
Thank you all for your prompt responses.
I think I'll go with a second MTRX Studio.
I attached a drawing trying to understand the connections between MTRX Studio(s) and HDX Card.
My understanding is:
A1 to C1
B1 to C2
Do I need a connection between the MTRX themselves?
again thank you for your help and for sharing knowledge ;-)
Ram: 80GB
Old 04-29-2021, 01:11 PM
JCBigler's Avatar
Why would you buy another MTRX Studio? There's better and cheaper ways to do this.
Justice C. Bigler
MTRX Studio with HD I/O nedd Pro Tools | MTRX & MTRX Studio 37 07-04-2023 04:58 PM
MTRX Studio i/o Cheesehead Post - Surround - Video 9 02-21-2021 08:17 AM
MTRX Studio - AVB [email protected] Pro Tools | MTRX & MTRX Studio 3 02-03-2021 02:32 AM
Mtrx Studio DB25 Avid Cable for analog input cerisaie Pro Tools | MTRX & MTRX Studio 11 11-16-2020 02:21 PM
MTRX Studio question about analog inputs and line level polyh3dron Pro Tools HDX & HD Native Systems (Win) 3 08-07-2020 12:23 AM
