2022.4 Import Audio Window Size
Hey all,
Yet another bug I am experiencing with 2022.4 on an M1 Max MBP on Monterey 12.4: Using the Import Audio window, I have to repeatedly drag the bottom right corner down in order to see any files from the finder. When I use Import Audio, here is what the window looks like (See attached). I use list view, FYI.
---------------------------------------------------- MacOS 12.4 / Pro Tools Ultimate 2022.4 |
Re: 2022.4 Import Audio Window Size
Same problem here.
I think I first noticed it with 2021.12 - it may have been earlier.
Pro Tools 2023.9 Ventura 13.6 |
I found the fix for this issue. For some reason, Pro Tools was not given "Full Disk Access" in the Security & Privacy tab. I had to manually add it. Import Audio window not remembers the size I set it to.
Unfortunately, I can't try it on 2022.4 - I installed 2022.5 a couple of hours ago. 2022.5 seems to remember the Import Audio window size without ticking "Full Disk Access".
Import session data window size Help!!! | Blackers | Pro Tools 12 | 2 | 05-16-2016 08:59 AM |
10.1.1 Import Session data window size bug? | meech | macOS | 0 | 03-27-2012 09:25 AM |
Feature request - audio fader mods in Import Audio window | digidesigner | Pro Tools TDM Systems (Mac) | 0 | 04-22-2009 12:14 PM |
Audio Import: 2GB Size Limit Workaround? | Mount Royal | Pro Tools TDM Systems (Mac) | 2 | 12-03-2008 09:05 AM |
Import Audio search window results will not import | BA Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-25-2008 09:00 AM |
