Stereo Aux not Routing to Master
It's really weird...All of a sudden, on a certain project some of my aux channels are not routing to the Master Fader. But, I can still hear them!!! These are inputs from my slave machine and I can hear the audio coming from them. But when I bounce to disk...non of these auxes are there. They are not metering on the Master Fader at all...
Any ideas? Andrew
DAW - ProArt B550-Creator / 5950X / 128GB / WD SN850 1TB / PT 2023.9 / RME UFX+ Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 2023.9 |
Re: Stereo Aux not Routing to Master
And just FYI, all of the problem auxes have their output set to "Analog 1-2, S/PDIF L-R (Stereo)".
I can get it to work when I create a Submix Aux and send all the problem auxes to it, then send that to the Master. It will bounce fine when doing this. hmmmmm...probably something simple that I have changed without knowing? Andrew
I'd just set the output of the Aux track to Bus 1-2 Stereo and use an empty regular Stereo track with it's input set to the same (Bus 1-2 Stereo), and then record enable the regular stereo track and begin recording. You'd hear everything but the regular Stereo track should only be picking up the Aux track's noise.
Doesn't make it any faster than to do the Submix Aux. I've never sent an Aux to the master.
Kryst |
Low latency monitoring makes it so that a musician recording a new track does not hear an echo of himself in his earphones. But when editing and mixing and bouncing the session, it is best to disable low latency monitoring. The PTLE firewire interfaces have a digital hardware mixer that routes inputs directly to the earphones for low latency monitoring of the mic/line inputs if the track's output is set to analog 1/2. In this mode, the signals of these tracks are not routed to the master meter. And aux sends from these tracks don't work the same. Never have "low latency monitoring" enabled during a bounce. So, disable "low latency monitoring" when you don't have a musician laying a new track. Also, you might want to read about "input only monitoring/auto input monitoring" in the "track" menu. This related setting effects how low latency monitoring functions.
MBox 2 Pro connected to motherboard 4 pin firewire port Dell Inspiron 9300 laptop 2.0 gHz Pentium M 2 gB ram Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter Roland 700SX stage piano Studio Projects C3 mics Melodyne Plugin Dual Boot: PTLE 8.0.1 on Windows 7 Enterprise 32 bit PTLE 8.0.1 on XP Media Center SP3 |
Routing to give a stereo group a stereo plugin on the VENUE plus AES EBU uses | somtech | VENUE Live Sound Systems | 5 | 05-19-2012 06:43 AM |
trouble routing to master fader | radioinactive | Pro Tools TDM Systems (Mac) | 15 | 11-02-2010 11:35 AM |
Routing around the Master Fader | 2hip2b4real | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-05-2008 11:25 AM |
002 spdif master routing - why can't I do this? | Kurt Riemann | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-02-2004 08:51 PM |
Routing output of master fader | MPB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-14-2003 12:44 PM |
