Old 01-24-2008, 12:54 PM
crizdee's Avatar
crizdee crizdee is offline
Default Magma PE64R Chassis or upgrade PCI cards to PCIe
Have bought a new Intel Mac (Harpertown 8 core not compatible yet and leopard only!) should i upgrade my HD3 accel to PCIe or should i buy the Magma PE64R chassis?
2 concerns!
1. reliability with a chassis
2. latency with a chassis (read on the magma site that this chassis has better latency than previous others!?)
Do chassis users still have to have the hardware buffer set twice as high?
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-24-2008, 01:45 PM
ZEUSS ZEUSS is offline
Default Re: Magma PE64R Chassis or upgrade PCI cards to PCIe
Mine is rock solid. You might want to have the option to run more than 3 cards at some point. My buffer is set to 128 with no problems.
Mac OS 12.6.6 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2023.3
Macbook Pro, 2019 (15,1) Mac OS 12.6.6 Monterey,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2023.3, Apollo 8 Silver,TwinX.
Old 01-24-2008, 03:08 PM
bad jitter bad jitter is offline
Magma rocks. Much cheaper option, too. Mac Pro 8 Core (older 3GHz), 4 Gigs Ram, Magma PE6R4, HD4 semi-Accel, 7.3.1 and OS 10.4.9 here.
Old 01-24-2008, 03:56 PM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Working perfectly for me. No latency tradeoff that I can tell .. 4 cards and growing. Smart way to go IMHO. I waited till there was a no latency punishment option. Magma is it
Ainslie
http://www.ainsliegrosser.com/
MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio
Old 01-24-2008, 04:03 PM
Top Jimmy's Avatar
Totally agree on the PE6R4. Nary a problem since getting up and running. See previous posting.
http://duc.digidesign.com/showflat.p...v=#Post1189243
James Cadwallader
Mac Studio, 64GB RAM, 1 TB SSD, Glyph 2TB USB3 HDD, OWC drive dock, Mac OS Monterey 12.6.2
Pro Tools Ultimate 2022.12, HD Native, Focusrite Red 8Pre
Old 01-24-2008, 04:21 PM
crizdee's Avatar
Thanks for sharing the info. Sounds like the way to go then
Just need to get a flight to US to buy one!! UK price is scary
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-25-2008, 09:13 AM
Vaporhead Vaporhead is offline
I agree. The Magma rocks. No problems here. You also get a real world opportunity to see that two regular old Process cards are definitely more powerful than one Accel card. I just keep adding Process cards to have in addition to the Accel cards that came out of the computer.
Old 01-26-2008, 07:13 AM
RobbyPowell RobbyPowell is offline
This is good news to me.. cause I'm thinking about it too..
I was just wondering..
Can you use the smaller chassi with only 4 PCI-slots (PCI4DRQ) for my HD2 rig? Or will there be some issues with latency or so?
/Robby
Old 01-26-2008, 01:53 PM
Top Jimmy's Avatar
The issue would be compatibility, not latency. If this expansion chassis is not specifically listed as supported, and it's also not listed as incompatible, then buy it and try it with absolutely no assurance of success. Currently, I believe the PE6R4 is the only supported PCI to PCIe host expansion chassis available.
James Cadwallader
Old 01-27-2008, 02:22 AM
scottgreiner scottgreiner is offline
there's this thread that sheds a little more light on the topic:
http://duc.digidesign.com/showflat.p...part=1#1236894
FS: HD2 PCI-x in a Magma 2-slot chassis with PCIe card Justin1524 Buy & Sell 5 11-29-2013 01:09 PM
Magma Chassis host card - which PCIe slot? Allan Speers Pro Tools TDM Systems (Mac) 2 09-07-2012 09:54 PM
PCI HD Accel cards, Magma pci chassis and newer PCIe Macs CD Productions Pro Tools TDM Systems (Mac) 8 10-07-2008 08:03 AM
New Magma PCIe to PCI Chassis www.Silentservice.de Pro Tools TDM Systems (Mac) 2 05-05-2006 11:44 PM
PCI cards in Magma chassis... Patrick P Pro Tools TDM Systems (Mac) 7 05-02-2000 12:40 AM
