Old 06-28-2000, 07:44 AM
smrp smrp is offline
Default Sound Replacer
I'm looking at buying Sound Replacer but I'm not totally clear on a couple of things.
1. What format will my samples need to be in? (.wav, .aiff, etc.) So I know what sample CD's to buy.
2. Won't replacing the drum sounds get a little screwed up in the overheads? I'll still hear a bunch of the original sound. How do you guys deal with this?
Old 06-29-2000, 11:40 AM
F Umminger F Umminger is offline
Default Re: Sound Replacer
SoundReplacer currently supports WAV and SDII files. I am a little vague on how well the SDII support works on Windows since SDII saves information in the resource fork.
The solution to leakage from undesired drums is to set triggering threshholds.
Frederick Umminger
Digidesign PlugIn Engineer
Frederick Umminger
Digidesign Plugin Engineer
Old 07-03-2000, 11:43 PM
Sean Halley Sean Halley is offline
As far as triggering goes, you've got a couple of options here: If all of the drum tracks are on a pair of channels (submixed), you can make a couple of copies of the tracks and simply chop out the stuff you don't want triggered for that instrument (ex: chop out everything but the kick and trigger from that).
I would plan on using it for augmentation (not replacement) until you get the hang. If your snare sucks hugely then use a sidechain comp and compress any stinky ring by something like 60 db. Use Sound Replacer to add a snare sample that has qualities the real snare now lacks and blend them together... Line up the triggered snare and the real snares by nudging until they're right - the overheads should still be useable in some way....
In general, you have to decide which is the worst of two evils (remember those thresholds...). If you're "replacing" the real kit, then I assume either the sounds are not great or you're going with a new idea. If you're replacing **** sounds then you'll have to deal with some of the pitfalls of triggering. If you're going with a new idea then go all the way: if it's a ride-based groove and you want to make it sound tighter and more wack , replace the kick and snare with tighter/nastier stuff, and then add something like Bruno (or Mondo Mod set to swish followed by Amp Farm..) to the ride track. Re-invent it instead of trying to re-create it....
Hope that helps...
Sean H
"it's not about making the changes, it's about playing ideas in time"
Scofield...
Sound Replacer mastermorris Tips & Tricks 2 01-28-2007 06:33 PM
Is there a drum replacer/sound replacer??? sethbrand General Discussion 2 03-08-2006 08:40 AM
my sound replacer makes the samples sound higher joeldavidlauver Pro Tools TDM Systems (Mac) 2 05-24-2005 07:59 AM
Sound Replacer Alters Sound of Sample. vze24x2x Pro Tools TDM Systems (Mac) 0 10-25-2003 07:10 PM
Need help with Sound Replacer Matty Spindel General Discussion 2 03-13-2002 11:55 PM
