How do you make a plug-in inactive?
I can't seem to find any information on how to make a plug-in inactive. The only reference I've found has the Mac keystrokes [img]images/icons/frown.gif[/img] . Thanks!
Re: How do you make a plug-in inactive?
controll + click on the insert. it will become highlighted--this means it is inactive
Click "bypass" on the plug in.
ctrl+windows left click on the plug-in should disable it. the letters get italicized and grey.you must be on stop mode to do this.
thanks blueroom! where did you find that?
you got it blueroom.
Note: bypass is different than inactive. - bypass does exactly that. it gives you the sound without that plug-in. it still uses the same amount of CPU juice - inactive disables it, and takes it out of the CPU loop so you can do other things. inactive is great for us old computer people because you can do a submix, then make the plugs inactive and continue on, without having to save the settings and go through searching all the saved settings. - i once watched a pro (because he's done it for a while, and gets paid to do it) use PT Le for mastering. He loaded all the songs in on different stereo tracks, loaded the plugs, made them inactive, and then muted/unmuted tracks to listen to what he wanted, as well as switching the plugs in and out by making them active/inactive. No fiddling with settings, but different settings on each track. darryl |
oh yah, ctrl and rt-click does it too
darryl |
No Start Key, How to Make Plugins Active/Inactive | acstctws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-16-2012 12:55 PM |
Make midi inactive. | supergirl36 | MIDI | 10 | 08-22-2011 06:34 PM |
Make Plug-in Inactive | Bocrickle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-12-2008 02:48 AM |
OK that was weird..."Make Track Inactive" bug? | bashville | Pro Tools TDM Systems (Mac) | 4 | 02-09-2007 01:07 AM |
Can one make a track inactive and hidden at once? | KenSluiter | Pro Tools TDM Systems (Mac) | 4 | 12-01-2006 01:25 PM |
