Help! Region bin empty !?!?!
I was doing some rather dense editing yesterday, and once I was finished, I faded and consolidated my tracks, after which I noticed that my regions bin is EMPTY! My stuff is still playing fine, but I can't clear regions I'm not using, or access them in any way. The files must still exist. Has anyone had this happen, or figured out a way to fix it? Thanks in advance!!
Re: Help! Region bin empty !?!?!
from the region menu select show auto created regions.
do you have a search phrase in the "find" field of the regions list? clear the "find" and your regions will appear.
--Jeremy |
I've also experienced this a handful of times... there must be a limit to how many regions the bin can keep track of, but I don't know if it's based on available RAM or a PT capacity issue. Never had a problem as a result, though, everything's still all there.
Speaking under the YMMV clause, I've tried both of the above suggestions with no success. The only workaround I know of is to create a new session & import some — not all — tracks into it; then the regions reappear. However, if you import one TOO many tracks, they all go away again... inconvenient & unnerving but not a meltdown. Hope this helps. Warmest Regards, Brian |
How make region list default to last-created region? | peytontodd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-22-2011 08:39 AM |
When hilighting a region protools hilights same region in ALL tracks! | djcnote | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-30-2010 11:29 AM |
Strike MIDI Region empty after reopening session | soundmaster | Virtual Instruments | 17 | 10-20-2009 02:07 AM |
First note in region is lost after copying/duplicating region | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 04-22-2009 04:46 AM |
How can I expand region in region list to its full lenght? | Ale | Pro Tools TDM Systems (Mac) | 2 | 10-08-2008 10:38 PM |
