  #101
Old 03-25-2023, 03:03 PM
Eric Lambert's Avatar
Default Re: Pro Tools 2023.3 is out
Originally Posted by bernstudios View Post
anyone running 2022.10 and 2023.3 on the same M1 machine without problems?
I'd shy away from doing this if possible. As PT versions start to get further apart, things like preference files begin to deviate and PT may not like swapping back and forth. i.e: 2023.3 adds some components to the Pref file which 2022.10 won't understand. It may work fine until one day you alter one of those parameters that are unique to 2023.3, then it creates trouble.
Unless they reference different (bespoke) pref files, but I don't believe that's the case.
  #102
Old 03-25-2023, 04:47 PM
Daveporter33765 Daveporter33765 is offline
Originally Posted by Eric Lambert View Post
It was definitely a problem back when PT was a 32-bit app and it couldn't work with more than 4GB oF RAM (not enough to get all plugin into memory that first time), but since PT11(ish) it should be able to load everything in without issue. Unless you have overall RAM limitations. How much RAM do you have?
Regardless, your comment about loading 1/2 at a time is a solid workaround. I'm just saying that it *shouldn't* be necessary with as far as PT is concerned.
I had to trash preferences after the 2023.3 update because I was not seeing several plugins. When I restarted Pro Tools Studio it crashed half way through validating my extensive plugin library several times. I had to resort to moving half my plugins out of my plugin folder and then starting Pro Tools. Then close Pro Tools and return all the moved plugins back into the plugins folder before restarting Pro Tools. Everything was fine after I set all my preference settings.
Luna 1.4.3, Logic Pro 10.7.7, Cubase Pro 12.0.60, Studio One Pro 5.5.2, Pro Tools Studio 2023.3, UAD-2 software 10.2.3, PreSonus Quantum 2, UA Apollo 8, UA Apollo Twin Mk 2 (2), UAD-2 Thunderbolt Satellite Quad (2), Fractal Axe Fx III Mk. II Turbo, Studio A: Apple iMac 2020, i7 8-core 3.8 GHz, 64 GB RAM, 1 TB SSD, RP5700XT GPU, 10 Gb/s Ethernet, MacOS Monterey 12.6.5. Studio B: Apple iMac 2015, i7 4-core 4 GHz, 64 GB RAM, 1 TB SSD, RP395X GPU, 1 Gb/s Ethernet, MacOS Monterey 12.6.5.
  #103
Old 03-25-2023, 10:49 PM
Fishbone Fishbone is offline
Just find out that Plugin Alliance silently released AAX Apple silicon native versions of almost all Lindell and NEOLD plugins alongside with a couple of other odd balls. Sweet!
MacMini M1 16Gb - MacOs 12.6.3 - Pro Tools 2023.3 - UAD Apollo Silver 8+16 - UAD Satellite octo - SSL UF8+UC1 - Softube Console 1 + Fader
  #104
Old 03-26-2023, 01:43 AM
JFreak's Avatar
JFreak JFreak is online now
My apologies for using the word "retarded". It is not such a strong word here. I promise to try to remember this in the future. Sorry for the upset everyone, it was unintentional.
Janne
  #105
Old 03-26-2023, 02:34 AM
thin ice thin ice is offline
Nice one Janne. It is too easy to get caught out these days, when there is no real intent.
Mac Mini M1 16 GB
OS 12.6.3
PT 2022.10
Mac Pro Quad Core
OS 10.8
PT9HD
  #106
Old 03-26-2023, 05:02 AM
K Roche's Avatar
K Roche K Roche is offline
I've had PT open for hours on end and there's no hint of such issues. I've not even heard of this from anyone else. I'd guess it's an unfortunate but unique problem, seemingly related to hardware/software interaction.
Yep it turns that at his facility there are multiple PT systems
Quote : Ok, I found the culprit(s). More my fault than anything else. On the way off chance that someone finds themselves in the same boat here's the scoop. Normal Pro Tools updates leave the i/o section and the peripheral sections untouched. I believe that was the case on my first install of 2023.3. On the second install, the peripheral setup was wiped out. So one of my midi devices (the Faderport) was sending out midi data that Pro Tools didn't know how to handle. Softsynths would just get this barrage of midi data and that turned into distorted, regurgitating noise, and ultimately into feedback. I merely had to rebuild the peripheral section and everything got rock solid.
System :
Avid Carbon interface , PT Ultimate 2022.10 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Ventura 13.2 .1
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
  #107
Old 03-26-2023, 05:47 AM
fredrikalpi fredrikalpi is offline
Default Re: Pro Tools 2023.3 is out: bugs
Too many bugs with PT 2023.3: shortcuts only appear as QWERTY even if your system is set on AZERTY. Several plugins won't work (Empirical Labs Arousor and Big FrEQ, as well as Two-Notes Torpedo Wall Of Sound, amongst others). I went back to 2022.9. Seems wiser at the moment, until all these bugs are solved by Avid and plugin developers.
  #108
Old 03-26-2023, 06:22 AM
Sardi Sardi is offline
A plugin not being AS native is not a bug.
  #109
Old 03-26-2023, 08:40 AM
Jay_uk Jay_uk is offline
Maybe 'Tardy' (slow/latecomer) was on the tip of your tongue, it has the same Latin derivation. I can see how it may differ in other Countries. It was unintentional and context is everything.
back to topic...
  #110
Old 03-26-2023, 09:58 AM
RobertDorn RobertDorn is offline
back to topic...
Yes, back to topic. Pro Tools is finally out of beta stage for silicon native. And now opens as silicon native by default instead of under Rosetta2. Big hand for all third party developers who were super fast in porting their plugins to AAX silicon. For all developers that have had silicon native versions of their AU/VST3 plugins for almost 2 years now and still need to find the time to do the same thing again for AAX: understandable. Eventually, the real latecomer here has been AVID
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Universal Audio Apollo X4 & 2 Octo Sattelites | Pro Tools Ultimate 2023.3 | macOS 13.2
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 10:33 AM
2023 Apple Silicon and Pro Tools Chevron Pro Tools 59 03-21-2023 07:54 AM
What’s due in 2023? noiseboyuk Pro Tools 56 03-13-2023 01:15 PM
32 Channel - Apple Silicon - Pro Tools Rig in 2023 ? T-Low Pro Tools HDX & HD Native Systems (Mac) 25 01-02-2023 09:30 PM
