Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 08-25-2021, 04:19 AM
LDS LDS is offline
Default Re: MTRX Studio - Output fine, no input now
Originally Posted by Matt Stephanson View Post
Thanks, LDS!
So really no reason to keep the OMNI, then.
Sounds like I need to invest in some more converters of the ADAT variety to get those last 8 i/o happening within PT.
Thanks folks. Will do some more digging.
Best,
Matt
I sold my Omni for exactly the same reason. ADAT is probably your best bet without chewing up Dante channels for stuff like Atmos.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 08-25-2021, 12:16 PM
Matt Stephanson Matt Stephanson is offline
Thanks again, LDS!
So just to confirm: one doesn't need to combine the MTRX Studio with another digi interface in order to work in Pro Tools.
If that's so, I can get rid of the entire HDN+Omni setup, and run things via an 8 ch. ad/da's adat i/o.
Does that make sense?
Last edited by Matt Stephanson; 08-25-2021 at 04:02 PM. Reason: Forgot to thank LDS :)
Old 08-25-2021, 01:50 PM
creativecontrol's Avatar
Correct. If you are happy running FF PCIeR + MTRX ST -> that's fine. Just don't run DVS as your primary conduit to MTRX ST.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-25-2021, 04:01 PM
Got it, Jeff. Thanks, that makes sense. I need at least the MTRX + a RedNet card.
This sounds like a more stable system than just relying on DVS.
I’m hopeful that will reduce the random dropouts I was getting.
Cheers all!
Old 08-28-2021, 04:44 AM
LDS LDS is offline
Cheers all!
Depends what you are trying to achieve. The MTRX Studio with the HDN card will be pretty similar in function when using Pro Tools.
  #16
Old 08-28-2021, 07:59 AM
Yes - agreed. A few comparisons for engines to connect to a MTRX Studio:
HDX - Hybrid engine, DigiLink, 64 Channels of IO per card (up to 192 IO), Frame Edge Alignment (via SYNC X or SYNC HD), Dante available
HDN - Native engine, DigiLink, 64 Channels of IO, Frame Edge Alignment (via SYNC X or SYNC HD), Dante available
PCIeR - Native Engine, 64 Channels via CoreAudio, No Frame Edge, Dante allocated
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
MTRX Studio Output Analog Level Specs Discrepancy Picture Start Pro Tools | MTRX & MTRX Studio 2 07-01-2021 09:03 AM
ProTools MTRX studio - PT can't play, UA Apollo works fine windmillaudio Pro Tools | MTRX & MTRX Studio 2 04-21-2021 02:37 AM
Mtrx Studio DB25 Avid Cable for analog input cerisaie Pro Tools | MTRX & MTRX Studio 11 11-16-2020 02:21 PM
192 enclosed optical output seems dead! input working fine! crizdee Pro Tools TDM Systems (Mac) 0 04-05-2008 11:16 AM
