Mixing In Pro Tools Vs. an Analog Console?
How are the Bomb Factory Plug Ins? In specific, the LA-2A and 1176 & Fairchild and Moogerfooger bundles. Right now I'm using Waves Platinum, T-Racks & Amplitube. I'm always looking to add more, fat analog sound quality to my mixes.
I'm trying to get use to the plug-in feel of effects, EQ's, compressors, limiters, ect. rather than the feel of using a hardware unit. There is something to be said about twisting knobs and buttons, rather than using a mouse or arrow keys. Do you think the plug-ins are as good as the real hardware versions of the originals? I'm using the Digi002 and it's cool, but there is something about mixing through an old console with designated EQ knobs for each channel, inserts and aux knobs and a rack full of the old original gear. Pro Tools can't be beat for editing and automation, but I'm still up in the air about mixing on it. Does anyone else feel the same way or have any suggestions? I study allot of pro engineers and what they use to mix and it seems that there are 3 trains of thought. 1. Engineers that record on 2" tape and mix on old analog consoles with all outboard gear. Great fat and broad sound. Especially noticeable in Drums and bass. 2. Engineers that record on 2" tape, then dump to Pro Tools and edit, then dump back to tape and mix on old analog consoles with outboard gear. 3. Engineers that track into Pro Tools running through vintage gear. Do all their edits in Pro Tools, and then mix on an SSL console or old analog console. I never hear too much about pro engineers mixing in Pro Tools, only doing edits and minor automation with some plug ins. Seems they always like to come back out to a console to mix. This is my observation, as I am still searching to find the best way to record and mix. I love Pro Tools for editing and automation, however I am still debating on mixing in Pro Tools with my Plug Ins and Digi002 or coming out to some kind of console with out board gear to mix. What are your thoughts and feelings on this subject? I know everyone has there opinions on this and I'd like to hear them. I guess once you get use to EQing and mixing in Pro Tools, it could be done, it just seems that more professionals do it the way I described above. There must be a reason for that. Thanks in Advance! |
Re: Mixing In Pro Tools Vs. an Analog Console?
Any thoughts on this???
www.pspaudioware.com Quote:
They are certainly out there, those who mix entirely in the box, and like it or not, there will be many more. The love of mixing on an analog board will not dissapear, those who can do it this way will most likely keep at it, but there are many more engineers and producers now than there were merely 10 years ago, and mixing on such boards is not a reality for many of them, including myself. Quote:
Well, yes, there is a reason. Analog circuits massage audio signals in a way a DSP cards cannot, that's a plain and simple fact. A Neve or SSL colours the sound and captures a much wider dynamic range when hitting the tape. So generally speaking, yes, I think mixing on analog to 2" will always sound better than 1's and 0's, sometimes marginally better, sometimes incredibly better, that depending on who's playing the tune and who's conducting the knobs. You do get used to mixing in ProTools, however, everything sounded like crap when I first started. I didn't know how to get good levels in, I didn't know how to eq and compress properly, much less did I know what an AD converter was, everything sounded like cardboard. You learn a lot in 4 years of doing the same thing every day and staying passionate about it. If I had the money, I wouldn't even buy a board to mix on. Knowing what I know, I'd invest in more high-quality preamps and compressors (UA, Brent Averill, TubeTech, Distressors, Pendulum, Manley, etc.), as well as AD and DA converters and keep mixing in PT. What you failed to mention was, are you in a position where you can mix on a good board if you chose too? If so, then your answers may be laying in front of you this whole time, though you seem to be wanting more than just opinions on the subject, but validation from others on either decision you make. I don't think that there's much to debate in this case, really. If you have access to a good board, then by all means use it. Why not try a mix in ProTools alone and see how you like it? You'll get opinion out the yin-yang on this one, but eventually, it's gonna come down to deciding for yourself. Try one, try the other, and just use what sounds better to you.
www.myspace.com/krou |
As a sound engineer I will attest to hearing the 'analog' difference. My last session, I had a vintage Trident board wired up to a ProTools rig via 4 ADAT XT-20s. (It was a splice job, not my first choice for going digital, but the 20-bit I/O held up.) Could you do a side-by-side comparison of direct in to ProTools vs. the console? Sure. You'd get better digital resolution going in, but what does that get you? More leeway with compression and s/n ratio. You'll have to downconvert to stick it on a CD anyway. What every engineer wants is a unique sound, a signature style. Digital doesn't afford that as part of the recording process. This is why we go nuts with plug-ins. Quote:
Chaos is a name for any order that produces confusion in our mind. --George Santayana |
How about sending all the outputs OUT to an analog mixer (max is 16 outs only from Digi 001 / 002 / 002R), and with all faders set to unity on the analog mixer, and with the main outs routed back into Digi 001 / 002 / 002R as a stereo Aux channel?
Would the above routing give Pro Tools (TDMs/HDs/LEs) the analog warmth?? Be it a mackie or a SSL, would the approach gives it the difference?
:: TWO ROOMS pte ltd :: Audio Post Production :: for Film / TV / Radio / Internet / Multimedia :: www.tworooms.com |
best you can get but it sound so fantastically sweet, and the Hi and Low EQs give quite a "niceness" (not to overexaggerate as to call it "warmth") to my sounds, that goes missing when only working digital, and the loss of "qualtiy" in the resampling cycle can be neglected. The point is the right gear in the right place works wonders! In my setup is, as I mentioned in other threads, a small tube compressor, a analogue Filterbank and my analogue mixpad, and that stuff is killer! compared to price/sound ratio. To be precise I have a very hard time in finding arguments to "if and why and what" additional plug-in can be justyfied to buy, and in most of the times I decide against a purchase. OF course this is not perfect, but I am working on it my story so far, best
last: PT11.3.1 |
With a hardware that nearly can´t be obtained anymore, like Fairchild etc, there is at least some sense behind it. best
last: PT11.3.1 |
How do you calculate 16 out from the Digi 002? I am in the process of trying to integrate a Soundtracs CM4400, and as best I can figure, I can only assign the 8 analog out, plus 2 alt main outputs for a total of 10. Am I missing something? Thanks in advance.
Regards mixing in the box versus through a console, I had always believed the console should be better, but recent experience has proved the monitoring and ears of the engineer has a lot more to do with it. An album project I have tracked on a 001 then the artist took off to be mixed in a 'real' studio resulted in mixes that were marginally better than my monitor mixes, and in the case of the two strongest songs on the album, weaker - he ended up using my mixes for the final album. The 001 in-the-box mixes were wider, warmer, more depth just generally bigger than the analog console versions, and that's without using a gazillion plug-ins (maybe that's why). So use your ears, and you can get great results. Note: I don't use the 001 stock mic-pres or A-D. I think that has a lot to do with it.
8 analog 8 ADAT lightpipe, you can get an Alesis AI-3 or similiar device for a few hundred bucks. 2 SPDIF, many options for againa few hundred on up for conversion to analog. IF you have good converters, and a good sounding console, IMHO it gretly improves the sound of the digital domain by running through analog. I hate mixing in the box, and only do so with additional tracks into protools. the first primary 24 tracks go analog via Mackie HDR 24/96 through a Soundtracs solologic with VCA and mute automation. 2 mix from Protools via Apogee converter mixes an additional 32 tracks back into the console. |
Mixing with analog console | johnnyz | Pro Tools HDX & HD Native Systems (Mac) | 8 | 07-07-2011 09:32 AM |
Analog Console vs ProTools Mixing TEST | teacherman | Tips & Tricks | 1 | 08-16-2007 09:15 AM |
Pro Tools vs. Analog Console Mixing... | Tony Shepperd | Pro Tools TDM Systems (Mac) | 29 | 08-13-2007 11:07 AM |
PT vs. Analog Console Mixing | Shan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-04-2007 07:40 PM |
Interfacing 888 analog output with analog console | Siegfried Meier | Pro Tools TDM Systems (Mac) | 3 | 09-12-2003 01:26 PM |
