6.9 using up TONS of CPU
As soon as I installed 6.9, all my sessions started crashing because of a reported lack of power. These are sessions that were running fine on 6.7 - I read that option dragging plug-ins could overload the processor in 6.9, but does this also apply to anything I might have Option-Drug in the past? It seems this should not affect the session once it is restarted - if so - all my previous sessions where I have Option-Drug (drag) will not work?
Anyone else have this problem? The problem system is: MBox G4 Aluminum Powerbook - 1.3GHz 768 Megs of Ram LaCie Firewire drive OSX 10.3.8 PT 6.9
Kurt Bullock PT 7.4 HD2Accel Digi ProControl G5 Dual 2.7 3.5gig RAM OS10.4.8 www.zeropointrecording.com |
Re: 6.9 using up TONS of CPU
You checked that the setup hasn't gone back to 60% CPU usage, this always gets me when i trash prefs.
yeah - thats back up to the highest it can go
Pro Tools 6.9 works best with journalling turned on - have you tried enabling journaling for your audio drive?
does 6.4 work best with it on, or off?
how bout 6.7? |
Well - in the documentation it says that it works best with Journaling on -
Ive got it on, both drives. the only other thing that has changed between 6.7 and 6.9 in my setup is the Pultec bundle I bought.. I installed that on the LE system.... thats it. Everything else has stayed the same on my part. Any known issues with the Pultec bundle? Its the newest version... Anyway - its stil pooping out on sessions I created and ran in 6.7....
oops - you were refering to 6.4- in that case it is my understanding that journalling should be off...
It becomes a problem if one is working on a project on different systems.
Journaling OFF has been the kind of ProTools default recommendation, so all my existing drives are formatted that way. If I cannot run from a 6.4 system to an HD system to 6.9LE interchangeably, I cannot really work.
William Wittman Producer/Engineer (Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!) |
Does 6.9 take advantage of a dual processor?
Produce - have you tried the steps in the 'General Troubleshooting' sticky at the top of this forum, specifically the sections on trashing prefs and databases?
Regarding it 'pooping out' - what errors are you getting (the error number)? Is you H/W Buffer size the same as it was in 6.7? Are you using any of the newly installed plug-ins in your session? Do you recall where your CPU usage was at in the 6.7 sessions and how it compares to CPU usage in the 6.9 session? What type of drive are you recording and playing back from? wwittmann - you can interchange any Pro Tools LE or TDM version from 5.1 on up. There are 2 caveats: 1. Sessions saved in Pro Tools with a +12db fader gain (PT 6.4 or higher) will open in a previous versoin of Pro Tools, but mix levels above +6 will be incorrect, as previous versions cannot go above the +6db limit. 2. Pro Tools 6.9 sessions that are opened and saved in a previous version of Pro Tools will lose some data specific to 6.9. This information is covered in the Read Me for Pro Tools 6.9. |
8.0.3 = Tons of Static | imloggedin | Pro Tools TDM Systems (Win) | 44 | 02-06-2010 01:34 PM |
Plug-Ins using tons of CPU | RichrdC | Pro Tools M-Powered (Win) | 0 | 08-27-2009 04:26 PM |
Amplitube Using Tons of CPU | RichrdC | Pro Tools M-Powered (Win) | 11 | 08-16-2009 07:53 PM |
Tons and Tons of Outboard Gear | TommyComa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 06-18-2007 11:43 AM |
tons of questions for you all | fuelie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-26-2002 02:22 PM |
