Old 01-09-2009, 06:23 PM
77pro 77pro is offline
Default Elastic Audio won't work? try this
I had this issue a while back on 7.4 and found a fix.
I just upgraded to 8 , and had the same issue, with all kinds of error dialogs popping up saying entry points couldn't be found and the app. failed to start...... and referring to iZotope_Radius_Win32.dll.
Sure enough, everything worked in 8 except Elastic Audio.
So I went back to my previous fix and moved < iZotope_Radius_Win32.dll > to
.......program files/Digidesign/Protools , from the install location of
.......Program Files/Common files/Digidesign/DAE/Plug-ins , and all is good
Don't know if anyone else had this problem....but if you do, try moving the file as outlined above and save yourself a lot of time.
003r/i7-930/LE 8.0.1 cs2 on xp
Old 10-18-2009, 06:58 AM
johnbhoy johnbhoy is offline
Default Re: Elastic Audio won't work? try this
ahhhh.... you da man.... Pity i had already uninstalled and cleaned preferences and all sorts before finding this thread.
All back up and running again.... what a waste of 2 and a half hours though/
I had this problem after i upgraded automap
Old 10-27-2012, 01:07 PM
Jslim Jslim is offline
Thanks
Old 10-27-2012, 03:29 PM
Glad it helped.....haven't been here for a while because everythings working just great!!
Old 04-26-2013, 08:30 PM
echopathy echopathy is offline
just ran into this prob. with pt9. your suggestion worked like a charm, 77pro. thanks!
Old 05-22-2013, 06:30 PM
Dexxy's Avatar
Dexxy Dexxy is offline
Thank you so much ... there for days struggling around these errors in protools 10.3.5 and your Instruction I solved the problem ..
Thanks again
Old 05-31-2013, 03:18 PM
rovingbovine rovingbovine is offline
Thank You!!
On PT 10, just place the file in the Avid/Pro Tools folder
Old 06-15-2013, 10:41 AM
Merc Merc is offline
Im getting this error with Protools 10 but i can't find that .dll anywhere! Not in my Protools folder or my DAE folder in common files. Any suggestions? A windows search doesn't bring anything up either. Thanks!
Old 12-03-2014, 06:21 PM
MetallicaSG1 MetallicaSG1 is offline
Just found this thread and have run into this same problem, cannot find the dll. anywhere! PT10 still opens and operates but an annoying message pops up each time it's opened saying dll. cannot be found etc.
anyone know how to fix this? THANKS!
Help Elastic Audio will not work properly OnTrak macOS 2 04-18-2012 08:06 AM
Why won't elastic audio work in PT8..? jtrainer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-26-2011 07:12 PM
Elastic Audio work flow question kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-29-2009 06:57 AM
Elastic Audio does not work on old sessions until... soundboy35 Pro Tools TDM Systems (Mac) 3 07-22-2008 06:32 PM
Cannot get Elastic Audio to Work on Mac Pro PT 7.4 Khaarmeyer Pro Tools TDM Systems (Mac) 4 11-22-2007 09:06 AM
