Old 12-04-2023, 12:23 PM
c-post c-post is offline
Default toggle all tracks doesn't work right
Hey, when I hold down option and press the hyphen key, toggle all tracks isn't working. I should be able to toggle all tracks between regions and volume. For some reason, when I start up a session, OPTION/HYPHEN only toggles the volume lines on, but OPTION/HYPHEN won't toggle the volume lines off. Am I getting rusty? What am I doing wrong?
thanks
John
"TISH! You spoke PROTOOLS! Speak some more protools, Tish... disk allocation, degree of thinning, timeline insertion...ANYTHING!"
Old 12-04-2023, 12:40 PM
BScout BScout is offline
Default Re: toggle all tracks doesn't work right
option+hyphen is working here to toggle back and forth (but I'm 2023.9)
You are in the legacy section, so which version of Pro Tools?
Pro Tools Ult 2024.10.2, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface ProS1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 14.7.2RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 12-04-2023, 08:29 PM
6.4.1. Yeah, this function had worked properly for years. Hmmm, I wonder what happened. Option DASH is one of those essential commands for Protools to run smoothly.
John
Old 12-04-2023, 09:09 PM
The obvious answer is to reinstall 6.4.1
J
Old 12-04-2023, 09:45 PM
J
You might just need to trash preferences instead of doing a reinstall (a reinstall won't fix it if it is preferences because that won't get cleared out/over written)
Old 12-13-2023, 01:04 PM
Oh WOW. I forgot all about that. DEFINITELY worth a try! Even if it doesn't work, THANKS A BUNCH. Guess I'm a bit rusty.
JCG
Old 12-13-2023, 03:00 PM
Yeah, I tried trashing Protools 6.4.1 preferences and that didn't work. OPTION/hyphen turns ON volume for all tracks as it's supposed to, but it won't turn volume OFF, failing to return to region editing.
thx
John
Old 12-28-2023, 11:39 AM
Even after reinstalling PT 6.4.1 again and trashing prefs again, option-dash STILL does not turn off volumes for all tracks. My next option is to swap out my main drive for a backup I have and try that.
JCG
Fit All Tracks Vertically shortcut - doesn't work Gorantovic Pro Tools 4 09-20-2021 11:30 AM
ZOOM TOGGLE doesn't work when PT is playing Benny Mouthon Pro Tools 3 08-05-2021 03:31 AM
The shortcut to toggle to next or previous playlist doesn't work reznovmax Pro Tools 12 0 06-07-2021 08:02 AM
Tab to transient doesn't work on elastic tracks BGee Pro Tools TDM Systems (Mac) 2 11-09-2007 12:07 PM
toggle view keyboard shortcut doesn't work Saar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-10-2003 08:54 AM
