Beat Clock to MPC via MTP AV?
I'm trying to sync an MPC to PT via a MTP AV using beat clock. The MPC is definitely recieving midi and I have beat clock enabled to the mtp av. Is it something in clockworks that I have to do?
Thanks for the help. |
Re: Beat Clock to MPC via MTP AV?
I also would like to know that with midi clock sync. Wanna sync a XP80 sequencer. Seems old version 4.3 is not capable, but will version 5.1.1 allow me that? thanks to all
Alécio Costa Studio High-End e-Mastering & Music Production www.aleciocosta.com http://www.facebook.com/alecio.costa PT Ultimate Native 2023.3 - Mac Mini M1 16GB RAM - Mac Os Ventura 13.2 - 2 192 IO Digidesign Digital PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 2008 16GB RAM Mastering Gear: Pendulum Audio, Crane Song, Avalon, Great River, Sebatron, Sonnox, Izotope, PSP, TC, Fab Filter. |
-Is FreeMidi running in "OMS Compatibility" mode? -Is your MTP AV recognized as such in OMS? (the MTP AV device icon should be purple with the MOTU unicorn behind/above it) In the MIDI>MIDI Beat Clock window of Pro Tools, I would suggest enabling the MPC item and not the MTP AV. In the MIDI section of the Transport window, make sure that the Conductor button is highlighted. Brent |
Brent |
Thanks Brent. I'll give it a try.
thanks Brent! I have versions 4.3, 4.3.1 and now 5.1 and 5.1.1. Basically, SPP/midi beat clock will be already going out of a midi cable to a device like XP80, MC50 via MTP Av, right?
Still stuck. Midi beat clock only shows mtpav, clockworks and iac bus. OMS setup has been done. MTPAV shows it's recieving something when protools is playing (BEAT CLOCK?) and MPC is recieving midi because it plays the click.
Hi There
Make sure in OMS you have a Device that is the MPC. Open that device in OMS and enable send and recieve MIDI Beat clock. Save. In Pro Tools, enable MIDI Beat Clock under the MIDI menu. Also enable the MTPAV. Your device does not show under the MIDI Beat clock devices because the interface once enabled outputs MIDI Beat clock on all MIDI ports. Ok, software is now set (remember to set the tempo in Pro Tools to the tempo that you want the track to be since Beat clock transmits Tempo). On the MPC choose MIDI input and set it for M Clock with SPP. Go into song mode, hit play in Pro Tools and you should be rolling. Also remeber that "Clock works" is only used with Free MIDI and Digital Performer and should not be used with OMS. MJ Digidesign Tech Support |
Brent |
thanks again BRENT! nothing as installing 5.1.1 next week to face the thing!
Triton...is MIDI Clock difrnt than MIDI Beat Clock | BookSix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-12-2006 12:24 AM |
indigo arp/beat clock bug in pt6 | fathermac101 | Pro Tools TDM Systems (Mac) | 2 | 04-15-2003 02:28 PM |
MTC Vs. Beat Clock | fresh_meat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-02-2002 03:54 PM |
Beat Clock | TommyT | Pro Tools TDM Systems (Mac) | 0 | 10-22-2001 08:23 PM |
Beat clock yes, MTC NO!!!!!!!!!! | izotropix | Tips & Tricks | 0 | 10-05-2000 08:26 AM |
