Old 08-22-2010, 08:08 AM
jonnycof jonnycof is offline
Default distortion on inputs
Hi all,
Every few minutes or so, my inputs into pt suddenly become incredibly distorted. If I record, the files have this distortion on them. If I go into settings> playback engine and just quickly toggle on and off the "ignore errors during playback" option, the distortion goes away for a few minutes, as if it's been reset. As far as I can tell, there's no one specific situation that brings about the distortion - it just happens all the time. I'm not running any plugins.
This is definitely a pt problem as I can monitor my delta inputs and there is no distortion on these even when there is in pt.
I have played about with my buffer size with no success. I have also done the general trouble shooting steps.
A search of the forums reveals that a few people appear to have had similar issues, but solutions to the problem don't seem to have been posted on these treads. Here's a couple of links to people I've found with similar issues...apologies if I've missed a thread which already tackles this problem.
http://duc.digidesign.com/showthread.php?t=279626
http://duc.digidesign.com/showthread.php?t=231731
My Sandra report is in a post below.
New here, so hope I've provided all the neccessary information. I'd be very very grateful for any help,
Jonny
Old 08-22-2010, 08:09 AM
Default Re: distortion on inputs
SiSoftware Sandra
Computer
Model : Dell Precision T1500
Workgroup : WORKGROUP
Host Name : jc
User : Jonny
Processor
Model : Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
Speed : 3GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Mainboard : Dell 0P67HD
BIOS : Dell 1.0.1 09/18/2009
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 8GB DIMM DDR3
Chipset
Model : Dell Clarksfield/Lynnfield DMI
Front Side Bus Speed : 2x 2.4GHz (4.79GHz)
Chipset
Model : Intel Core Desktop (Lynnfield) UnCore
Memory Bus Speed : 2x 665MHz (1.33GHz)
Memory Module(s)
Memory Module : Hynix (Hyundai) HMT125U6BFR8C-H9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : NVIDIA Quadro FX 580 (32 SM4.0 1.1GHz, 512MB DDR3 2x800MHz, PCIe 2.00 x16)
Graphics Processor
Storage Devices
Seagate ST3320418AS (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (D:)
Seagate ST3320418AS (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (C:)
Generic Flash HS-CF (USB) : N/A (G:)
Generic Flash HS-COMBO (USB) : N/A (H:)
TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 7GB (E:)
TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:)
Logical Storage Devices
DATAPART1 (D:) : 298GB (NTFS) @ Seagate ST3320418AS (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
RECOVERY : 750MB (NTFS)
Hard Disk (C:) : 297GB (NTFS) @ Seagate ST3320418AS (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
Removable Drive (G:) : N/A @ Generic Flash HS-CF (USB)
Removable Drive (H:) : N/A @ Generic Flash HS-COMBO (USB)
M-Powered (E:) : 7GB (CDFS) @ TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (F:) : N/A @ TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Dell P55 LPC Interface Controller
LPC Legacy Controller 1 : Fintek F71882FG/F71883FG
Audio Device : Dell P55/PM55/3400 High Definition Audio
Audio Device : VIA M Audio Delta-66
Serial Port(s) : 1
Disk Controller : Dell P55/PM55/3400 6 port SATA AHCI Controller
USB Controller 1 : Dell P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : Dell P55/PM55/3400 USB2 Enhanced Host Controller
FireWire/1394 Controller 1 : Dell FW322/323 IEEE1394 OHCI FireWire Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Peripherals
Media Player : ()
Media Player : ()
Network Services
Network Adapter : Broadcom NetLink (TM) Gigabit Ethernet (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Old 08-24-2010, 08:55 PM
lcsper lcsper is offline
What interface are you using?
Old 08-25-2010, 05:26 AM
m-audio delta 66, latest drivers.
Thanks for any help,
Jonny
Old 08-31-2010, 01:51 AM
somebody plllleeeeaaassse help! Anyone know anything about this problem?
massive distortion on guitar inputs wav28 Pro Tools SE and Essential (Win) 0 03-05-2012 10:29 AM
Using Eleven Rack inputs like POD X3 inputs dayslypper Eleven Rack 1 10-09-2010 09:15 PM
How do I utilize the Line inputs when all my XLR inputs are being used? 007audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-23-2009 08:21 PM
Pops, Crackles, Distortion on VI's and Inputs cziebold Pro Tools M-Powered (Win) 1 02-12-2009 09:37 AM
MBOX2 MINI - Distortion on inputs? fredmaher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-25-2006 02:39 PM
